| Throttle cable froze up http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=47829 |
| Author: | mudslut [ Sat Nov 30, 2013 8:19 am ] |
| Post subject: | Throttle cable froze up |
Is there anything I can do to keep the cable from freezing up? Sent from my iPhone using Smoke Signals |
| Author: | BayouStateHunter [ Sat Nov 30, 2013 8:32 am ] |
| Post subject: | Re: Throttle cable froze up |
Antifreeze in a Cajun injector into the cable |
| Author: | mudslut [ Sat Nov 30, 2013 8:51 am ] |
That's a good idea Sent from my iPhone using Smoke Signals |
| Author: | MNGunner [ Sat Nov 30, 2013 10:27 am ] |
| Author: | mudslut [ Sat Nov 30, 2013 10:44 am ] |
This is the second morning in a row it has done it. The motor stays under my carport and the trailer freezes to the bottom of the boat. Sent from my iPhone using Smoke Signals |
| Author: | swampbilly [ Sat Nov 30, 2013 12:40 pm ] |
Mine was froze at the carb yesterday mornin, so last night I wrapped an old Tshirt around it then taped a plastic Walmart sack on it. Took it off at the boat ramp this mornin and didn't have a problem with it. |
| Author: | barrelburner [ Sun Dec 01, 2013 7:39 am ] |
Hey guys mine has froze too many times then I care to speak of, motor was useless in cold weather. I would have too exercise the throttle in the back of the boat manually which was dangerous. Just an idea and not sure if it will work for your motor but I was getting desperate and pissed off. What I did was remove a section of throttle cable sleeve in the middle exposing it and left about 10 or 12 inches on each end. It has worked great since then and no more problems. I keep the exposed part of the cable greased a little bit too stop corrosion and rust. Cable is cheap to replace vs the aggravation of a froze cable at ( O Dark Thirty in the morning). Just to add, my throttle cable is unconventional because I use a small screen door pulley and wheel clamped to the handle bar too keep the angle of the cable small before it hooks to the throttle arm on the motor. |
| Author: | barrelburner [ Sun Dec 01, 2013 7:43 am ] |
Also, forgot to mention motor is a 6.5hp homemade surface drive. |
