It is currently Wed Dec 17, 2025 6:16 pm
Reply to topic  [ 12 posts ]
 Stage 2 issue
Post Stage 2 issue
Running my 35 Briggs today and it began to lug down and lost power unless reving out of water
Now idling back to launch and can't get over 1300rpm. If I give it more throttle it chokes down and dies
Thinking my mikuni boot may have cracked any other ideas to check?
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Dec 21, 2013 1:19 pm
Post Re: Stage 2 issue
Check ur intake where it bolts on. If gasket is blown it will do that. With motor runnin spray wd40 under the cowling towards where it bolts on. If ur idle changes, that's ur problem.
Sent from my iPhone using
pd36 fpr 1754 cc rig
Sat Dec 21, 2013 2:05 pm
Will do
Thx
12 ft 11hp longtail
Merc 225hp TR20
Sat Dec 21, 2013 2:11 pm
Mine did the same thing except the bolts had started backing out where my intake bolts on.
Sat Dec 21, 2013 2:21 pm
Found the problem
12 ft 11hp longtail
Merc 225hp TR20
Sat Dec 21, 2013 3:36 pm
No leaks on carb
It is odd how it occurred tho, almost like it was starving for fuel and would run at first but did not have any power, then it got to the point it would run but only at idle was thinking fuel or valve issue
I pulled one valve cover off and checked them and thought one was too loose so I reset it best I could without feeler gauge while still on water
when I got home, I cranked it, sprayed wd40 and no change, ran it up to rev limiter and it ran fine
Pulled plugs and the port side was wet so I pulled valve cover and found bent exhaust rod
But odd thing is it ran fine on the trailer before I pulled the plugs
12 ft 11hp longtail
Merc 225hp TR20
Sat Dec 21, 2013 3:54 pm
they will run pretty decent on one cylinder with no load on them!
Sat Dec 21, 2013 3:59 pm
16x44 Hanko Skiff
35GTR
Sat Dec 21, 2013 5:55 pm
Sun Dec 22, 2013 9:07 am
Cool! An aluminum Boomerang!!
Sun Dec 22, 2013 10:02 am
Post Stage 2 issue
12 ft 11hp longtail
Merc 225hp TR20
Sun Dec 22, 2013 10:48 am
1748 Phowler with a 35 CDI MB Sport with heads, single mikuni, cam, and gutted stock exhaust
Mon Dec 23, 2013 5:18 am
