It is currently Mon Dec 15, 2025 9:23 am
Reply to topic  [ 9 posts ]
 Gtr trim problem
Post Gtr trim problem
I have a 2007 gtr and the trim was working fine the night before the hunt next morning while I was running it decided to quit working. Both relays are clicking when I hit the switch up and down. Any advice would be appreciated
Thu Dec 26, 2013 1:13 pm
Post Re: Gtr trim problem
Relays are bad.... Or I had the same problem 3 weeks ago replaced them and she works better then ever now.
Thu Dec 26, 2013 1:32 pm
I appreciate the help ill change them both and see if it works
Thu Dec 26, 2013 1:52 pm
My inline fuse spring was corroded and gave me fits until I figured it out. Don't overlook it also. I replaced it with a weather proof blade style on my 2009.
Thu Dec 26, 2013 8:42 pm
Changed both relays and there still clicking. Checked all my wiring which is also good. Could it just be the actual trim is out?
Thu Dec 26, 2013 10:38 pm
I believe so, mine is doing the same thing
Thu Dec 26, 2013 11:03 pm
Could be a few things, bad connection, fuse, relays, worn brushes, armature shaft orings are shot and oil flooded the motor compartment.
Seen all these issues in the past few months. all simple fixes.
Thu Dec 26, 2013 11:12 pm
Jump the trim out straight to the battery to see if its bad.
Fri Dec 27, 2013 12:56 am
Is your battery good and fully charged? Might not be getting enough amps to "throw" the relays.
Fri Dec 27, 2013 6:52 am
cron
