It is currently Wed Jun 18, 2025 7:44 pm
Reply to topic  [ 8 posts ]
 Stuck in neutral
Post Stuck in neutral
I have a 2008 mud buddy hyper35 up hyper drive. Sometimes my engine will get stuk in neutral. I will move the switch back and forth and nothing then all of a sudden it goes into gear. I already put on a new switch. How can I fix this?
Wed Jan 01, 2014 1:09 am
Post Re: Stuck in neutral
i had the same problem with mine the other day but mine would not go in gear . you need to pull your clutch cover off and make sure one of your wires are not loose on your clutch itself .
Wed Jan 01, 2014 3:16 am
Make sure u have 12volts before it goes into the belt housing before you go through the trouble of opening the belt housing.
1648 gd hull flying in front of a stage 3 with fpr
Wed Jan 01, 2014 12:35 pm
I had an issue like this with mine (2010) and I had a bad clutch breaker(?) It is the two prong party that completes the circuit. Was a 5 dollar fix.
Sent from my SCH-I535 using Tapatalk
Don't be a "Melvin"...
Wed Jan 01, 2014 2:25 pm
Low voltage, prob the culprit
16X48 WELDBILT -25GTR EFI-sold
18x48 GTB - 35 GTR
Crown royal pro-staff
Wed Jan 01, 2014 2:36 pm
This only happens every once in a while not all the time. Can I check the voltages when it is still working or do I have to wait until it us not working to check.
I figured the switch was. Working because when I have engaged it won't start.
Also if anyone has any pics that would help. I'm not very mechanically inclined.
Wed Jan 01, 2014 3:18 pm
What mine would do, is when in gear and running, it would go into neutral.
Wed Jan 01, 2014 3:39 pm
I had the same issue, picked up another on/off/momentary on switch from radio shack (most of them have them in a drawer somewhere). Fixed the problem, but I would check the voltage also, just in case it's more of an issue than a bad switch.
Wed Jan 01, 2014 9:06 pm
Users browsing this forum: No registered users and 196 guests
