Stuck in neutral
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=48751
Author:  j towne [ Wed Jan 01, 2014 1:09 am ]
Post subject:  Stuck in neutral
I have a 2008 mud buddy hyper35 up hyper drive. Sometimes my engine will get stuk in neutral. I will move the switch back and forth and nothing then all of a sudden it goes into gear. I already put on a new switch. How can I fix this?
Author:  ducks an diesels [ Wed Jan 01, 2014 3:16 am ]
Post subject:  Re: Stuck in neutral
i had the same problem with mine the other day but mine would not go in gear . you need to pull your clutch cover off and make sure one of your wires are not loose on your clutch itself .
Author:  renovator [ Wed Jan 01, 2014 12:35 pm ]
Make sure u have 12volts before it goes into the belt housing before you go through the trouble of opening the belt housing.
Author:  Perch_44 [ Wed Jan 01, 2014 2:25 pm ]
I had an issue like this with mine (2010) and I had a bad clutch breaker(?) It is the two prong party that completes the circuit. Was a 5 dollar fix.
Sent from my SCH-I535 using Tapatalk
Author:  Swampnuts [ Wed Jan 01, 2014 2:36 pm ]
Low voltage, prob the culprit
Author:  j towne [ Wed Jan 01, 2014 3:18 pm ]
This only happens every once in a while not all the time. Can I check the voltages when it is still working or do I have to wait until it us not working to check.
I figured the switch was. Working because when I have engaged it won't start.
Also if anyone has any pics that would help. I'm not very mechanically inclined.
Author:  Perch_44 [ Wed Jan 01, 2014 3:39 pm ]
What mine would do, is when in gear and running, it would go into neutral.
Author:  Russ [ Wed Jan 01, 2014 9:06 pm ]
I had the same issue, picked up another on/off/momentary on switch from radio shack (most of them have them in a drawer somewhere). Fixed the problem, but I would check the voltage also, just in case it's more of an issue than a bad switch.
