It is currently Fri Feb 13, 2026 5:45 am
Reply to topic  [ 15 posts ]
 Go Devil mods help
Post Go Devil mods help
How many of ya'll run a modded GoDevil 35SD?
Sun Jan 26, 2014 5:53 pm
Post Re: Go Devil mods help
I have a buddy who runs one with ported heads& intake with a 42 milk carb moded exhaust. Very strong boat. He says it runs 32mph. It does try to blo the prop out of the water on the top end though. He is gonna try a different prop to see if it will bite the water better. Is yours modded?
Mon Jan 27, 2014 10:43 am
Mon Jan 27, 2014 10:54 am
I am running one with everything but pistons .hoyt cam, roller rockers, Manley valves, 45 makuni.
I had one with pistons that pushed a 20x60 31mph. did not hold up long.
JD
Mon Jan 27, 2014 12:05 pm
Bump
Mon Jan 27, 2014 7:28 pm
mine is stock but looking to mod. Want more low end and load carrying capacity. Tired of it not getting on step when loaded down. It runs fast enough for me but any extra speed would be ok. It sits on a GD 16x60. Just want reliable mods that don't require having to work on it all the time.
Mon Jan 27, 2014 11:50 pm
Refurbishing a Prodrive
Tue Jan 28, 2014 5:31 am
Wed Jan 29, 2014 1:59 pm
Wed Jan 29, 2014 3:36 pm
Wed Jan 29, 2014 7:47 pm
Ok bc I ran that same gear and the speed difference was way more than 2 mph
Sent from my iPhone using
Wed Jan 29, 2014 8:03 pm
Thu Jan 30, 2014 12:37 am
16x54 GDSD
Simple.....
(was simple, now a rocket)
Thu Jan 30, 2014 9:34 pm
Fri Jan 31, 2014 9:35 pm
With lack a hydraulic trim, when your prop gets worn it wants to blow out of the water at high revs, you can bend your tabs to help this, but then your off once you put a good prop back on. It gets squirrely because when your prop blows out of the water at full speed to loose alot of control of the whole steering thing, which can be important sometimes. But, if your gonna drive a modded go devil remember to hit gym, they can be a handful sometimes.
16x54 GDSD
Simple.....
Sat Feb 01, 2014 1:48 pm
