| Go Devil mods help http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=49645 |
| Author: | BAG Hunter [ Sun Jan 26, 2014 5:53 pm ] |
| Post subject: | Go Devil mods help |
How many of ya'll run a modded GoDevil 35SD? |
| Author: | Will C [ Mon Jan 27, 2014 10:43 am ] |
| Post subject: | Re: Go Devil mods help |
I have a buddy who runs one with ported heads& intake with a 42 milk carb moded exhaust. Very strong boat. He says it runs 32mph. It does try to blo the prop out of the water on the top end though. He is gonna try a different prop to see if it will bite the water better. Is yours modded? |
| Author: | Gameover [ Mon Jan 27, 2014 10:54 am ] |
| Author: | JD [ Mon Jan 27, 2014 12:05 pm ] |
I am running one with everything but pistons .hoyt cam, roller rockers, Manley valves, 45 makuni. I had one with pistons that pushed a 20x60 31mph. did not hold up long. JD |
| Author: | Skeith48 [ Mon Jan 27, 2014 7:28 pm ] |
Bump |
| Author: | BAG Hunter [ Mon Jan 27, 2014 11:50 pm ] |
mine is stock but looking to mod. Want more low end and load carrying capacity. Tired of it not getting on step when loaded down. It runs fast enough for me but any extra speed would be ok. It sits on a GD 16x60. Just want reliable mods that don't require having to work on it all the time. |
| Author: | brycecheramie [ Tue Jan 28, 2014 5:31 am ] |
| Author: | JD [ Wed Jan 29, 2014 1:59 pm ] |
| Author: | AKA Freshwaterkilla [ Wed Jan 29, 2014 3:36 pm ] |
| Author: | JD [ Wed Jan 29, 2014 7:47 pm ] |
| Author: | AKA Freshwaterkilla [ Wed Jan 29, 2014 8:03 pm ] |
Ok bc I ran that same gear and the speed difference was way more than 2 mph Sent from my iPhone using |
| Author: | JD [ Thu Jan 30, 2014 12:37 am ] |
| Author: | mattpittinger [ Thu Jan 30, 2014 9:34 pm ] |
| Author: | BAG Hunter [ Fri Jan 31, 2014 9:35 pm ] |
| Author: | mattpittinger [ Sat Feb 01, 2014 1:48 pm ] |
With lack a hydraulic trim, when your prop gets worn it wants to blow out of the water at high revs, you can bend your tabs to help this, but then your off once you put a good prop back on. It gets squirrely because when your prop blows out of the water at full speed to loose alot of control of the whole steering thing, which can be important sometimes. But, if your gonna drive a modded go devil remember to hit gym, they can be a handful sometimes. |
