It is currently Sat Feb 14, 2026 5:32 am
Reply to topic  [ 6 posts ]
 water injection......
Post water injection......
any of you gear heads had any dealings with snow products and water injection? I am considering adding this to the 25....
http://www.snowperformance.net/stage-1- ... ooler.html
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Fri Jan 31, 2014 11:40 am
Post Re: water injection......
I've found this also ... Again to the motor heads would or could it http://www.magnumtuning.com/en/detail/m ... /eh72-25-0
1744 WC Custom
25 GTR
Fri Jan 31, 2014 12:10 pm
I use it on turbo and supercharged cars to prevent detonation. It alows me to push the limits of what a motor will take. If your motor is not "on the edge " now then i dont see it makin much power . just alows more agressive compression and timing in the build .If your gonna try im very intrested to see how it goes. The meth part of the mix is like adding a higher octane fuel and the water side is to cool the air intake temps. Both of wich are to prevent detonation on a hot or force fed build
Fri Jan 31, 2014 12:25 pm
I been eyeballing an ecotron turbo....... let me free up some money and over the summer and I may have a 35 hp 25 ;)
Sent from my SCH-I545 using Tapatalk
Fri Jan 31, 2014 4:14 pm
I've used water and methanol injection on lots of engines. It can really improve performance just with its anti-detonation properties. I have lots of experience with snow performance systems and Devils Own as well. I'd say if you're fighting knock and heat go for it.
-Custom pool noodle
-stage 4 water wings
Fri Jan 31, 2014 5:05 pm
Just put an ATV nitrous kit. 20 horse wet kit on a WOT switch, arm it whenever you want and juice it for a few seconds to run a number or pass somebody up at a mud run :lol:
Fri Jan 31, 2014 5:25 pm
