It is currently Sat Feb 14, 2026 7:00 am
Reply to topic  [ 6 posts ]
 Coil issue??
Post Coil issue??
I have an 07 36 pd with a stage 1 by calen. On the last weekend of season I was doing a lot of idleing around, like 95%. Well on Sunday it died after I got to the hole and it would not start back. I thought i had just fowled the plugs, i didnt have any tools and just got a tow back. I just had a chance to look at it and the plugs were fowled bad the tillar side plug of the motor will not spark. It will run for just a few seconds and then die. Upon further inspection of the idle screw, I had apparently screwed it down quit a bit to make it idle. I think I may have a coil issue but how can I tell for sure without pulling the coil? Also why would I have to increase the idle so much? The screw was over half way down.
Fri Jan 31, 2014 11:24 am
Post Re: Coil issue??
Refurbishing a Prodrive
Fri Jan 31, 2014 11:53 am
I did not put new ones in, I just cleaned them up to see if I could get a spark...
Fri Jan 31, 2014 12:00 pm
Fri Jan 31, 2014 12:04 pm
Get a spark plug tester
Costs 5 bucks
Brandon M.
KCCO
B. MacDonald
Fri Jan 31, 2014 1:06 pm
Fri Jan 31, 2014 1:14 pm
