logriggers
Joined: Sat Oct 13, 2012 7:56 pm Posts: 303 Location: Fairhope, Al
 35 mb rev imiter
hey guys I'm still trying to get my carb tuned correctly. When i had my 23 I could run my motor wot without hitting rev limiter my 35 will not let me do that. will not run wot just hits rev limiter. I also am having trouble getting in to idle down. I have had mixed reviews. Some people said my govenor adjustment screw was screwed in too far some said bend the tab. I don't want to just go messing with stuff. Anybody have any suggestions or the proper way to set govenor screw and tabs?
_________________ 35 Mud buddy Stage 2 on a 1844 Uncle J
| Thu Jan 30, 2014 7:28 pm |
stopthetalk
 Re: 35 mb rev imiter
What RPM's are you at with the 35 GT? Is it on the same hull that you had your 23HP on? What is the size of your hull? What year is your 35HP GT? What is the condition of your prop?
I will try to help you if I know these questions.
| Thu Jan 30, 2014 7:42 pm |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
Fricken carbs... I swears
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
| Thu Jan 30, 2014 7:43 pm |
stopthetalk
My Bad!! You have a GT or a MB? My Bad Again!! Same Thing!!
| Thu Jan 30, 2014 7:44 pm |
logriggers
I have a mb. I cant tell you the rpm without load. Prop is new. With just me if i trim it up i can get 4000 but my problem is idling. I cant get it to idle below about 1700. Its an 05 on a 1648
| Fri Jan 31, 2014 12:32 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
Is it the Mikuni carb, if it is just turn the idle adjustment in/out start all the way in and come out like turn and 1/2 and see what it does.
| Fri Jan 31, 2014 12:35 pm |
logriggers
stock carb
| Fri Jan 31, 2014 6:19 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
A nine year old stock carb? Throw it in the trash and get a new one, and adjust it from there. That way, at least your not fighting issues with the carb it self.
Lots of guys sell new stock carbs cheap when they upgrade to the Mikuni's. MB sells them as well.
| Fri Jan 31, 2014 6:55 pm |
