pvt
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=49845
Author:  NannySlayer [ Fri Jan 31, 2014 10:28 pm ]
Post subject:  pvt
So I have decided to go with pvt to pep up the duck barge. I spoke with him the other day and he seems like a real knowledgeable guy. I have a stock 35 mb and I am leaning towards his flat top pistons, rods, rr, push rods, and a carb. I am goint to get him to work the heads and replace the valves.
Anyone run his setup? He also recamends a 38mm instead of the 42. Thoughts?
Author:  barnes_53 [ Fri Jan 31, 2014 10:46 pm ]
Post subject:  Re: pvt
He apparently had the original recipe for the MB 45 MAG and there was some sort of falling out with MB. Not sure how much that recipe has changed, but oddly the 45 MAG is still MB most dependable performance motor. I have talked to him before. Yes, he knows his stuff and I am positive some other guys will agree here too.
Author:  cupped up [ Fri Jan 31, 2014 10:48 pm ]
PVT is good peoples.
Author:  Bigrich [ Fri Jan 31, 2014 10:50 pm ]
And good parts
Author:  dfou [ Fri Jan 31, 2014 10:57 pm ]
Author:  Bigrich [ Fri Jan 31, 2014 11:02 pm ]
Author:  dfou [ Fri Jan 31, 2014 11:13 pm ]
Author:  Bigrich [ Fri Jan 31, 2014 11:25 pm ]
Yep!
Author:  NannySlayer [ Fri Jan 31, 2014 11:35 pm ]
Apparently he designed th mag 45 and built hundreds of them. Then mb ripped off some of his parts and that put an end to that.
Big, did his fail or do you have his ansd only have 20 hrs on them.
Author:  Bigrich [ Fri Jan 31, 2014 11:39 pm ]
Most guys don't like aftermarket push rods. Knock on wood mine are good and just have 20 hrs on them
Author:  NannySlayer [ Sat Feb 01, 2014 12:09 am ]
Are the aftermarket push rods the problem or are they being blamed for other things?
Author:  dfou [ Sat Feb 01, 2014 4:12 am ]
Author:  cupped up [ Sat Feb 01, 2014 5:53 am ]
Author:  Bigrich [ Sat Feb 01, 2014 6:16 am ]
This is true you can't build something bullet proof, their is always gonna b a weak link. The push rod is an easy fix. But is the the bent push rods a mechanical issue or the man that was behind the wrench that didn't know what he was doing??
Author:  dfou [ Sat Feb 01, 2014 6:18 am ]
Author:  Bigrich [ Sat Feb 01, 2014 6:20 am ]
True not all the time failure is do miss adjustment or lack of..
Author:  krogers [ Sat Feb 01, 2014 6:52 am ]
Author:  SCmudder7071 [ Sat Feb 01, 2014 8:14 am ]
Al is a great guy and knows his stuff. I'll be using his parts on my next boat as well. Really like the fact my work is five minutes from his shop.
Author:  cupped up [ Sat Feb 01, 2014 8:27 am ]
Author:  NannySlayer [ Sat Feb 01, 2014 11:03 am ]
He is close enough to visit but far enough away I have to make a Special trip.
Author:  SCmudder7071 [ Sat Feb 01, 2014 11:34 am ]
Cupped Up, it was definitely a problem when I had my rig that's for sure! I'll still drop in here and there and shoot the breeze with him.
Nanny, if there's anything you need a hand with, just shoot me a message. I actually live in Pageland, SC.
Author:  NannySlayer [ Sat Feb 01, 2014 12:17 pm ]
Thanks man... I will let you know when I head up there.
Author:  NannySlayer [ Sat Feb 01, 2014 12:18 pm ]
Sc, who are you on scducks?
Author:  SCmudder7071 [ Sat Feb 01, 2014 12:54 pm ]
Same handle as on here.
