Anyone else had this problem
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=49871
Author:  Colbeans [ Sat Feb 01, 2014 6:47 pm ]
Post subject:  Anyone else had this problem
I own a gtr35 and the oil cooler is leaking on the side of the motor anyone else ever seen this happen?
Author:  dirtybird29+ [ Sat Feb 01, 2014 7:09 pm ]
Post subject:  Re: Anyone else had this problem
Yep more than likely if you pull the hoses off at the oil cooler and tighten up the barbed fittings,it will prolly fix your problem. I had this problem also.
Author:  cupped up [ Sat Feb 01, 2014 7:24 pm ]
Or the cooler itself is cracked. Clean it up and look real good. I had a barb fitting I had to fix and an oil cooler cracked another time
Author:  missile [ Sat Feb 01, 2014 7:58 pm ]
Same as cupped up had both places leak.
Author:  Colbeans [ Sat Feb 01, 2014 10:14 pm ]
Thanks for the info but I have something else to ask have y'all ever had to replace the trim unit and if so how did work or sound before you had to replace it
Author:  doubleBanded [ Sun Feb 02, 2014 9:56 am ]
Mine is doin this also. Gonna try n fix when change oil
Author:  cupped up [ Sun Feb 02, 2014 10:10 am ]
Author:  Colbeans [ Sun Feb 02, 2014 2:14 pm ]
I've put trim fluid in it but it still sounds like nails going down a chalk board
Author:  Charlie-echo [ Sun Feb 02, 2014 2:59 pm ]
Mine is leaking around there too, motor has about 37 hours on it. I removed the fitting closest to the oil filter and used plumbers tape like a few guys on here suggested, but the problem is that the fitting won't tighten up enough, before it hits the block. The fitting is actually too long . Not sure how to fix that!
Author:  Colbeans [ Sun Feb 02, 2014 4:51 pm ]
I found today that it is the oil cooler that is leaking it has a hairline crack in it
Author:  Bigrich [ Sun Feb 02, 2014 4:56 pm ]
http://bakerprecision.com
Author:  schauv01 [ Sun Feb 02, 2014 6:47 pm ]
Yep! Had same problem
Author:  msm8281 [ Sun Feb 02, 2014 7:01 pm ]
http://www.bakerprecision.com/trucool.htm
Author:  Colbeans [ Sun Feb 02, 2014 9:06 pm ]
Y'all know what size the stock one is?
Author:  msm8281 [ Sun Feb 02, 2014 9:10 pm ]
