Mikuni Size for 14 Kohler
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=49961
Author:  txkingfisher [ Mon Feb 03, 2014 8:38 pm ]
Post subject:  Mikuni Size for 14 Kohler
What size Mikuni should I run on a 14 kohler? 440cc
Or would it be a waste of money and I should just drill our the jets on the stock carb?
I am planning to port/polish the head, maybe shave the head and advance the timing a little if I get ambitious, remove the governor, add a racing header and silencer.
Author:  autogateman [ Mon Feb 03, 2014 8:48 pm ]
Post subject:  Re: Mikuni Size for 14 Kohler
this one lol
Author:  msm8281 [ Mon Feb 03, 2014 8:50 pm ]
I need one like that for my weed whacker:lol:
Author:  txkingfisher [ Mon Feb 03, 2014 9:15 pm ]
Basically! hahahahaha
I've been looking at 24-34mm almost all of the adapters come with a 60mm bolt pattern but my head has a 52.5mm bolt pattern.
I'm thinking about buying the adapter and seeing if I can tweak it enough to fit just to see if the whole mikuni project is doable without a ton of hassle.
Author:  cheesypoof [ Mon Feb 03, 2014 10:16 pm ]
Just curious as to why you would want to put a Mikuni on the Kohler? I can understand on the Briggs engines because they have terrible hesitation coming off idle sometimes causing the engine to kill if you throttle up too fast, but I was under the impression that the Kohler's had no such problem (never owned one on a mud motor).
Author:  txkingfisher [ Mon Feb 03, 2014 10:19 pm ]
No, mine doesn't have that problem.
I just want to do some mods to make the engine breathe better. I want to be able to flow enough air and fuel to feed it after I do. Maybe the stock carb can handle the extra air and I can just drill out the stock jet.....
Maybe I should just scrap the Kohler altogether and build a 440cc honda clone that will take all the GX390 performance parts.
