| Will I need gear change after motor work? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=50436 |
| Author: | tlsmith22 [ Sun Feb 16, 2014 9:36 am ] |
| Post subject: | Will I need gear change after motor work? |
Have a 2012 45 that I am gettn headwork(port and polish, .015 decking) done right now and also adding a dual carb setup. The reason I am asking if I will need to change gears is I also am having to change the crankcase cover so I am gonna have the outdrive off. I am running a 2054 custom with a 32 in outdrive and a hammer prop with a single mikuni carb. Right now I am turning 4400 rpms solo and 4300 loaded down. I am running 38/48 gears. Do u think I will need to change to a 46 gear to keep the rpms down? I dont wanna run it towards the rev limiter all the time. Thanks guys |
| Author: | autogateman [ Sun Feb 16, 2014 9:53 am ] |
| Post subject: | Re: Will I need gear change after motor work? |
On that big of a boat I'd stay with those gears. |
| Author: | AKA Freshwaterkilla [ Sun Feb 16, 2014 2:28 pm ] |
X2 or go to a 50 t on the bottom that is a big boat Sent from my iPhone using |
| Author: | dfou [ Sun Feb 16, 2014 10:29 pm ] |
38/48 Sent from my iPhone using Tapatalk |
| Author: | The Hairy Coot [ Sun Feb 16, 2014 11:22 pm ] |
What factors will be affecting weight? What will be your estimated avg weight? Sent from my iPad using Tapatalk HD |
| Author: | 50fps [ Mon Feb 17, 2014 7:27 am ] |
You will want to keep the rpms up with the dual carb setup to see any benefit. 38/48 1.26-1 ratio is light to me. |
