It is currently Sat Aug 22, 2026 5:02 pm
Reply to topic  [ 10 posts ]
 removing stock carb for cleaning
Post removing stock carb for cleaning
Going to remove the stock carb for the first time and clean it ... motor isn't even a year old but it needs it apparently .... I have removed carbs and cleaned them on traditional outboards but not yet on this godevil 35hp sd ... any specific precautions besides not losing any parts during the process that you guys may advise?
Mon Feb 02, 2015 11:55 am
Post Re: removing stock carb for cleaning
Gasket kit Cost over 100 dollars
Mon Feb 02, 2015 12:29 pm
if you remove the jets - be sure to note where they go and re-install in the right place. They are diffrent sizes
Mon Feb 02, 2015 12:43 pm
Mon Feb 02, 2015 12:44 pm
Ok thanks
Mon Feb 02, 2015 2:35 pm
good luck - now that winters back,,,,
Mon Feb 02, 2015 3:43 pm
Unless the motor sat up for a long time and had the fuel crystalize in it or had a bunch of crap get in the bowl from degraded fuel lines, then it really shouldn't need any regular cleaning.
Not worth getting a 'rebuild kit' from Briggs, more cost effective to get one of the take-off new carbs from modded factory motors. BoatDr usually carries them- much less than the cost from Briggs.
If you need the gaskets between carb and intake adapter, I have a pile of leftovers from head gasket kits.
Mon Feb 02, 2015 4:35 pm
Ok thanks ... don't think I am going to need a rebuild kit since it's been used on a regular basis with fresh fuel and not even a year old motor
Tue Feb 03, 2015 4:45 am
Tue Feb 03, 2015 5:26 am
Ok will do
Tue Feb 03, 2015 8:50 am
