It is currently Mon Jun 30, 2025 10:43 am
Reply to topic  [ 10 posts ]
 Copperhead trim?
Post Copperhead trim?
Hey guys so I have a 12hp copperhead. Motor and everything works flawlessly. My problem is I can't get my manual trim to stay set, it just keeps backing out. Anyone else had this issue or maybe have some tips or tricks? Thanks
Sat Apr 26, 2014 1:15 pm
Post Re: Copperhead trim?
I have owned 3 and have never seen or heard of that problem. You could try some Loc-tite or bring it over to Copperhead as they have great service. Is there any chance you bent the prop and that is causing extra vibration or something?
Sun Apr 27, 2014 8:40 pm
Yeah my 14 did that. I took the factory trim off and added my own electric.
You can pm me on mmc if you want details. It was Easy to do.
Sent from my GT-I9195 using Tapatalk
Mon Apr 28, 2014 3:44 am
Every copperhead I have owned (3) did it.
Mon Apr 28, 2014 5:53 am
Mon Apr 28, 2014 5:57 am
For the guys that said they did have the problem, I am curious. Does your boat vibrate alot and what kind of boat is it? I have heard a boat builder say they redesigned to minimize vibration and harmonics which are a problem even with the Vanguard vtwin engines which are definitely smoother than the 1 cylinder engines.
I guess I could see it happening if you are bouncing off of logs and stumps alot as well. There are not many stumps in either of the areas I hunt.
Mon Apr 28, 2014 6:28 pm
Mon Apr 28, 2014 7:06 pm
Turn the backing nut in as if your tightening it, should fix ya up.
Fri May 02, 2014 8:45 pm
Profile YIM
what backing nut?
Sat May 03, 2014 5:13 pm
If you hold the motor off the trim it will back out on the few I've driven but as long as the motors on it it usually stays
Mon May 05, 2014 1:49 pm
Users browsing this forum: No registered users and 138 guests
