Copperhead trim?
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=52715
Author:  lay_out822 [ Sat Apr 26, 2014 1:15 pm ]
Post subject:  Copperhead trim?
Hey guys so I have a 12hp copperhead. Motor and everything works flawlessly. My problem is I can't get my manual trim to stay set, it just keeps backing out. Anyone else had this issue or maybe have some tips or tricks? Thanks
Author:  cheesypoof [ Sun Apr 27, 2014 8:40 pm ]
Post subject:  Re: Copperhead trim?
I have owned 3 and have never seen or heard of that problem. You could try some Loc-tite or bring it over to Copperhead as they have great service. Is there any chance you bent the prop and that is causing extra vibration or something?
Author:  txkingfisher [ Mon Apr 28, 2014 3:44 am ]
Yeah my 14 did that. I took the factory trim off and added my own electric.
You can pm me on mmc if you want details. It was Easy to do.
Sent from my GT-I9195 using Tapatalk
Author:  bengtr35 [ Mon Apr 28, 2014 5:53 am ]
Every copperhead I have owned (3) did it.
Author:  lay_out822 [ Mon Apr 28, 2014 5:57 am ]
Author:  cheesypoof [ Mon Apr 28, 2014 6:28 pm ]
For the guys that said they did have the problem, I am curious. Does your boat vibrate alot and what kind of boat is it? I have heard a boat builder say they redesigned to minimize vibration and harmonics which are a problem even with the Vanguard vtwin engines which are definitely smoother than the 1 cylinder engines.
I guess I could see it happening if you are bouncing off of logs and stumps alot as well. There are not many stumps in either of the areas I hunt.
Author:  bengtr35 [ Mon Apr 28, 2014 7:06 pm ]
Author:  Puddle jumper [ Fri May 02, 2014 8:45 pm ]
Turn the backing nut in as if your tightening it, should fix ya up.
Author:  lay_out822 [ Sat May 03, 2014 5:13 pm ]
what backing nut?
Author:  shotgunwilly1117 [ Mon May 05, 2014 1:49 pm ]
If you hold the motor off the trim it will back out on the few I've driven but as long as the motors on it it usually stays
