MarshJB
 Grass Screen
I had a noise coming from the grass screen. Took it apart and one of the studs was broken. I saw on here that some people said you need to keep the center ring and three bolts in. Can you just leave all of it off? The fan shroud has bolts holding it on already. I don't see how leaving the three bolts and rings in will help support the shroud.
Sent from my XT1080 using Tapatalk
_________________ 17x54 Extreme W/ GTR-35L Stage 1
Fri May 02, 2014 5:31 pm |
AKA Freshwaterkilla
 Re: Grass Screen
No u need that ring for support
Sent from my iPhone using
Fri May 02, 2014 5:35 pm |
MarshJB
 Re: Grass Screen
WHYYYYYYYYYYY! I guess I'll go buy some bolts to replace the studs with.
Thanks for the fast response, your a nice guy man, i don't care what they say about you. Lol;)
Fri May 02, 2014 5:37 pm |
prodrivinggatortail
 Re: Grass Screen
Just cut those studs about a half inch long and reinstall that plate with those shorter bolts. Then tye wrap the screen to the grille. You don't need Guidry's law degree to figure that out. Should be the first mod done to your engine.
Sat May 03, 2014 6:50 am |
AKA Freshwaterkilla
 Re: Grass Screen
Sat May 03, 2014 9:51 am |
MarshJB
 Re: Grass Screen
I replaced the bolts with regular hex heads, used fender washers and locks along with locktite. I just snugged them down over the ring. Ran it this morning and it's all good now, also gets rid of some noise that thing used to make.
I just took the screen off completely.
Because i used regular bolts i had to align the ring, wasn't a big deal, it's easy to eyeball it.
Sat May 03, 2014 9:57 am |
MarshJB
 Re: Grass Screen
Sun May 04, 2014 10:28 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: Grass Screen
Looks good,
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Sun May 04, 2014 10:44 am |
MarshJB
 Re: Grass Screen
I wish this site would upload full resolution pictures.
Sun May 04, 2014 10:55 am |
gfowel
Joined: Thu Mar 01, 2012 4:52 pm Posts: 1024 Location: Florida
 Re: Grass Screen
Other than getting rid of that noise any benefit to taking off the grass screen?
Sun May 04, 2014 11:15 am |
MarshJB
 Re: Grass Screen
Sun May 04, 2014 11:20 am |
gfowel
 Re: Grass Screen
Sun May 04, 2014 11:36 am |
AKA Freshwaterkilla
 Re: Grass Screen
Yea I'm sure it helps air flow a lil it would be like u breathing through a screen door it works but u still feel like someone is trying to smother u  Sent from my iPhone using
Sun May 04, 2014 12:00 pm |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: Grass Screen
_________________ that's going itch when it dries
Sun May 04, 2014 12:03 pm |
MarshJB
 Re: Grass Screen
Sun May 04, 2014 12:05 pm |
