Grass Screen http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=52918 |
Author: | MarshJB [ Fri May 02, 2014 5:31 pm ] |
Post subject: | Grass Screen |
I had a noise coming from the grass screen. Took it apart and one of the studs was broken. I saw on here that some people said you need to keep the center ring and three bolts in. Can you just leave all of it off? The fan shroud has bolts holding it on already. I don't see how leaving the three bolts and rings in will help support the shroud. Sent from my XT1080 using Tapatalk |
Author: | AKA Freshwaterkilla [ Fri May 02, 2014 5:35 pm ] |
Post subject: | Re: Grass Screen |
No u need that ring for support Sent from my iPhone using |
Author: | MarshJB [ Fri May 02, 2014 5:37 pm ] |
WHYYYYYYYYYYY! I guess I'll go buy some bolts to replace the studs with. Thanks for the fast response, your a nice guy man, i don't care what they say about you. Lol;) Sent from my XT1080 using Tapatalk |
Author: | prodrivinggatortail [ Sat May 03, 2014 6:50 am ] |
Just cut those studs about a half inch long and reinstall that plate with those shorter bolts. Then tye wrap the screen to the grille. You don't need Guidry's law degree to figure that out. Should be the first mod done to your engine. |
Author: | AKA Freshwaterkilla [ Sat May 03, 2014 9:51 am ] |
Author: | MarshJB [ Sat May 03, 2014 9:57 am ] |
I replaced the bolts with regular hex heads, used fender washers and locks along with locktite. I just snugged them down over the ring. Ran it this morning and it's all good now, also gets rid of some noise that thing used to make. I just took the screen off completely. Because i used regular bolts i had to align the ring, wasn't a big deal, it's easy to eyeball it. Sent from my XT1080 using Tapatalk |
Author: | MarshJB [ Sun May 04, 2014 10:28 am ] |
Author: | DmaxHunter [ Sun May 04, 2014 10:44 am ] |
Looks good, |
Author: | MarshJB [ Sun May 04, 2014 10:55 am ] |
I wish this site would upload full resolution pictures. Sent from my XT1080 using Tapatalk |
Author: | gfowel [ Sun May 04, 2014 11:15 am ] |
Other than getting rid of that noise any benefit to taking off the grass screen? |
Author: | MarshJB [ Sun May 04, 2014 11:20 am ] |
Author: | gfowel [ Sun May 04, 2014 11:36 am ] |
Author: | AKA Freshwaterkilla [ Sun May 04, 2014 12:00 pm ] |
Yea I'm sure it helps air flow a lil it would be like u breathing through a screen door it works but u still feel like someone is trying to smother u ![]() ![]() Sent from my iPhone using |
Author: | baron von [ Sun May 04, 2014 12:03 pm ] |
Author: | MarshJB [ Sun May 04, 2014 12:05 pm ] |
