It is currently Sat Jun 28, 2025 12:49 pm
Reply to topic  [ 34 posts ]
 35 GTR w/ Pro-Drive EFI & Pro-Drive heads
Post 35 GTR w/ Pro-Drive EFI & Pro-Drive heads
Added Pro-Drive EFI & heads worked by Pro-Drive to a 35 GTR. Heads were decked .040, port work, and valve job. Motor has a stock exhaust.
Before
- 3800-3850 RPMS
- Top speed of 26.2 MPH
After
- 4300-4350 RPMS
- Top speed of 30.5 MPH
- Compression is right at 152-153 psi on both cylinders
Saw a steady gain of 4 mph, while maintaining a quiet exhaust. Boat is big and heavy for an 18x48. I was surprised to see 30 mph.
Fri Apr 25, 2014 8:24 pm
Post Re: 35 GTR w/ Pro-Drive EFI & Pro-Drive heads
Nice speeds n info
What did it run ya
1852 Dfou custom 35gtr
Fri Apr 25, 2014 8:29 pm
18x48 w/ 3/16th bottom and 24" tall 1/8th sides. Big catwalks, huntdeck, 7 long stringers, big ass front deck with 2 storages.
Fri Apr 25, 2014 8:33 pm
what was the before compression?
how many hours and year of engine?
any porting/polishing done to intake manifold or plenum?
stop talking about EFI - until I get motor!
Fri Apr 25, 2014 8:50 pm
Fri Apr 25, 2014 8:54 pm
so you didn't have to do any polishing or "cleaning up" inside intake manifold - and the ports lined up with head ports - spot on?
Sat Apr 26, 2014 8:09 am
Correct, didn't have to touch them.
Sat Apr 26, 2014 8:22 am
Plug. [attachment=-1]uploadfromtaptalk1398624656614.jpg[/attachment]
Sun Apr 27, 2014 12:50 pm
very clean plug - how many PSI (fuel) does the system operate at?
Sun Apr 27, 2014 3:41 pm
42
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sun Apr 27, 2014 4:06 pm
Have they wrote a tune for a motor with an exhaust? Is the sensor the only addition to the stock muffler? Nice setup
Sun Apr 27, 2014 6:00 pm
Sun Apr 27, 2014 6:46 pm
2014 Pro Drive Gen 3
2014 17x54 X-Series
Sun Apr 27, 2014 9:21 pm
2500 I believe. It's on their website.
Sun Apr 27, 2014 9:27 pm
if your fuel cell is mounted forward in the boat do you need a "pusher" fuel pump by the tank?
Tue Apr 29, 2014 6:09 pm
Tue Apr 29, 2014 6:18 pm
Tue Apr 29, 2014 6:30 pm
Tue Apr 29, 2014 9:04 pm
Tue Apr 29, 2014 9:31 pm
If your cranking compression is 150ish and your heads have .040 of decking removed, you have a problem.
Cranking compression on stock heads is 150ish.
Heads decked .040 should be 170-180.
Sat May 03, 2014 11:55 pm
My compression with iron mountain heads was 150 on my old PD. I will do a compression check on my current stock Pro-Drive with 3 hours on it for a cross reference tomorrow.
Sun May 04, 2014 8:34 am
awesome... I'd love to add it to my motor
I gave up mud motors
Sun May 04, 2014 8:44 am
Retested the GTR with EFI. Got 157 & 158. The GTR has stock valves.
My stock PD registered 140 & 144
Sun May 04, 2014 12:15 pm
my heads are decked 40 thousanths.. I can pull a compression on it if needed.. I have manley valves.
Sun May 04, 2014 12:28 pm
I checked my motor and my buddies motor last week both decked. 040 another fried has heads decked the same. All 3 were 178-180.
Sun May 04, 2014 12:33 pm
I want to say Blue said his stock PD was 130 and 135 PSI, after decking .050 and some deshrouding he is at 160.
Sun May 04, 2014 12:43 pm
Pretty sure these are deshrouded as to why the higher numbers.
Sun May 04, 2014 12:46 pm
i need to check mine
Sun May 04, 2014 1:23 pm
Sun May 04, 2014 1:29 pm
17x54 Extreme W/ GTR-35L Stage 1
Sun May 04, 2014 1:35 pm
Sun May 04, 2014 1:50 pm
I just checked compression on my stock GTr and got 120/125
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sun May 04, 2014 1:56 pm
Now on my dual rig with cam and heads I'm seeing 175/180 on one motor and 155/150 on the other. Wonder why the different. I think they were decked. 035-.040
Sun May 04, 2014 1:58 pm
Just put a motor together with the heads decked .045 a little while ago. Compression 160 and 160. PVT cam and stock size Manley valves. 2 weeks ago i had some other heads decked .045 that went on a stock bottom end and the comp was like 160 and 150-something. My shits .055 with a PVT cam and 182 on both. I believe stock range between 135-145 depending on what kinda shape the motor is in.
Sun May 04, 2014 2:03 pm
Users browsing this forum: No registered users and 175 guests
