It is currently Mon Jun 30, 2025 1:31 am
Reply to topic  [ 14 posts ]
 What can I do with a stock 35 mudbuddy to get more power
Post What can I do with a stock 35 mudbuddy to get more power
I've been looking at doing something for a while with a stock 35 mudbuddy surface drive and was wondering what can I do to it to make it push a little better without doing a complete build. Example like exhaust, carb or what is the best for the money? I'm kinda new to this type of setup so just looking for some thoughts. The motor is a 2005 or 2006 mudbuddy with about 135hrs on the motor.
Thanks in advance
Also if u can give a rough price figure or where to look for any of the info or parts that would great also
Wed Jun 04, 2014 4:03 am
Post Re: What can I do with a stock 35 mudbuddy to get more power
Refurbishing a Prodrive
Wed Jun 04, 2014 4:21 am
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Wed Jun 04, 2014 6:09 am
Drop a couple teeth on top sprocket. Makes a big difference for little money.
Thu Jun 05, 2014 3:19 pm
1854 Prodigy Open
HDR/Stage 3 mods
Thu Jun 05, 2014 7:01 pm
Thu Jun 05, 2014 10:12 pm
Thanks for all the info. Keep it coming. I believe I'm going to start with exhaust what brands are the best and y?
Thu Jun 05, 2014 10:15 pm
Fri Jun 06, 2014 4:33 am
Fri Jun 06, 2014 5:05 am
Fri Jun 06, 2014 1:08 pm
Mon Jun 09, 2014 10:04 pm
Also what's the best type and size prop to run on this motor? And how do u measure it properly furthest outside points or center shaft to outside or what? Thanks
Mon Jun 09, 2014 10:06 pm
I ran the boat this past weekend it is a 1654 gator Trax my self and my 95 lbs lab and 6 gallons fuel one battery was running 24-25 mpg on gps I would like to see that during duck season with 2-3 guys and dog and gear but I'm not sure what it would take to do that. Is that a good speed with a stock motor or should it possibly be more. The rpms was about 3950 when wide open is that to much or is that safe? Like I said new to the mud motors I've seen different links about rpm zones but I'm just checking again
Thanks
Mon Jun 09, 2014 10:15 pm
That's pretty good for stock motor, wouldn't want to run it much over 4000 for very long with. If your going to push a heavy load and motor has a clutch, you can change out the prop shaft gear to a 50 or 52 tooth pully, This will allow motor to reach a higher rpm with load. You maybe able to turn a Big Blade Prop if you aren't already. Speeds won't be much higher.
Tue Jun 10, 2014 7:18 am
Users browsing this forum: No registered users and 98 guests
