It is currently Sun Dec 28, 2025 3:50 pm
Reply to topic  [ 3 posts ]
 Vanguard 23 idle problem
Post Vanguard 23 idle problem
I changed over to a leveler style throttle handle and I now my motor is running way above it. I can't seem to figure out what adjustment to make to get the idle back down. Does anyone have any ideas?
Sun Jun 15, 2014 8:01 am
Post Re: Vanguard 23 idle problem
Unhook the cable from the handle. If it goes down then the cable is too short.
Sent from my HTC One mini using Tapatalk
Sun Jun 15, 2014 8:02 am
Sounds like your cable still has tension on it somehow. No reason for the idle to change just from swapping to a lever. While it's running push the linkage on the carb closed to see if it will idle down, if so that's 99% you're problem.
-Custom pool noodle
-stage 4 water wings
Sun Jun 15, 2014 8:03 am
