| GT1 throttle grip http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=53952 |
| Author: | Pulpwood [ Sat Jun 14, 2014 9:29 am ] |
| Post subject: | GT1 throttle grip |
I don't know if it's me or not, but I broke my second throttle lady night. The plastic shatters. They replaced the first one with no questions asked, but the first outing I broke another one. Have any of you replaced yours with a metal one? Sent from my SM-G900V using Tapatalk |
| Author: | mizzippi jb [ Sat Jun 14, 2014 9:43 am ] |
| Post subject: | Re: GT1 throttle grip |
Yep. Lots of folks have. Use the search feature on here or Google it. Plenty of info Sent from my SM-G900V using Tapatalk |
| Author: | Pulpwood [ Sat Jun 14, 2014 10:27 am ] |
I'm not getting any results. Looks like my new phone got me on auto correct in the title! Sent from my SM-G900V using Tapatalk |
| Author: | mizzippi jb [ Sat Jun 14, 2014 10:37 am ] |
Use google. Type in mmt throttle lever. Or look at the bps throttle lever that mud buddy sells Sent from my SM-G900V using Tapatalk |
| Author: | krogers [ Sat Jun 14, 2014 11:00 am ] |
viewtopic.php?t=32559. Here's one Sent from my iPhone using Tapatalk |
| Author: | baron von [ Sat Jun 14, 2014 11:34 am ] |
bps works pretty good |
| Author: | baron von [ Sat Jun 14, 2014 11:45 am ] |
if you dip coat the handle in plastic coat (several layers) it makes it a little nicer |
| Author: | odass [ Sat Jun 14, 2014 12:12 pm ] |
Baron I like that idea maybe make it a little more comfy on those long runs |
| Author: | Wildberry [ Sat Jun 14, 2014 12:59 pm ] |
What's that on top of the tiller control box |
| Author: | doubleBanded [ Sat Jun 14, 2014 1:29 pm ] |
How much is that bps grip |
| Author: | LA Prop [ Sat Jun 14, 2014 1:31 pm ] |
I've sold about 15 bps throttles in the last month |
| Author: | msm8281 [ Sat Jun 14, 2014 2:01 pm ] |
| Author: | ajverret [ Sat Jun 14, 2014 3:16 pm ] |
Will the bolt right on to the old handle or do the need to be modified Sent from da mud hole |
| Author: | baron von [ Sat Jun 14, 2014 3:47 pm ] |
| Author: | msm8281 [ Sat Jun 14, 2014 3:52 pm ] |
You will have it down on the first trip. It still happens to me from time to time after 4 years. As far as I'm concerned it won't hurt anything. The engine will just die. Sent from my HTC One mini using Tapatalk |
| Author: | baron von [ Sat Jun 14, 2014 4:24 pm ] |
| Author: | LA Prop [ Sat Jun 14, 2014 5:46 pm ] |
| Author: | LA Prop [ Sat Jun 14, 2014 5:47 pm ] |
| Author: | LA Prop [ Sat Jun 14, 2014 5:50 pm ] |
The bps grip is 60$ with the cables or 50$ w/o the cable. And i would recommend not using the cable on the stock the s connector isn't the same size as the one for the gtr. |
| Author: | Wildberry [ Sat Jun 14, 2014 6:55 pm ] |
| Author: | msm8281 [ Sat Jun 14, 2014 7:57 pm ] |
| Author: | baron von [ Sat Jun 14, 2014 8:41 pm ] |
if you dip coat it be sure to give it a once over with course sandpaper (I think I used 60 grit) and clean it off i used acetone. The only way I got paint to stick to the mounting without cracking really bad was put some enamel in a cup with hardner and dip it in, 2 coats I put older bolts in bolt holes and removed bolts when paint started to setup and cleaned up with razor blade. I also gave the mount a once over with course sandpaper. now will it stick - I don't know but looks cool and has taken a few likes so far,,, |
| Author: | LA Prop [ Sat Jun 14, 2014 9:19 pm ] |
| Author: | msm8281 [ Sat Jun 14, 2014 9:21 pm ] |
Mikunis for both. For my dad's motor and mine. Sent from my HTC One mini using Tapatalk |
| Author: | baron von [ Sun Jun 15, 2014 9:28 am ] |
9-10 bucks @ home depot - in paint section? |
| Author: | baron von [ Sun Jun 15, 2014 9:38 am ] |
I also noticed GT runs throttle cable close to engine - thats ok I get it - but you want your cable to have as gentle as turns as possible also, this is what I did, used 1 zip tie on fan cage and a insulated wire hold down on engine on engine.jpgcableonfan.jpg |
| Author: | baron von [ Sun Jun 15, 2014 9:43 am ] |
here is what you need 1/4 inch drill to drill out hole on wire hold, small piece of vacuum line (split on screwdiver) to fit on cable and install |
