Pulpwood
 GT1 throttle grip
I don't know if it's me or not, but I broke my second throttle lady night. The plastic shatters. They replaced the first one with no questions asked, but the first outing I broke another one. Have any of you replaced yours with a metal one?
| Sat Jun 14, 2014 9:29 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: GT1 throttle grip
Yep. Lots of folks have. Use the search feature on here or Google it. Plenty of info
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Sat Jun 14, 2014 9:43 am |
Pulpwood
I'm not getting any results. Looks like my new phone got me on auto correct in the title!
| Sat Jun 14, 2014 10:27 am |
mizzippi jb
Use google. Type in mmt throttle lever. Or look at the bps throttle lever that mud buddy sells
| Sat Jun 14, 2014 10:37 am |
krogers
Joined: Fri Oct 29, 2010 8:24 am Posts: 1958 Location: Bristol, FL
viewtopic.php?t=32559. Here's one Sent from my iPhone using Tapatalk
_________________ 1754 GTB / 35 GTR
| Sat Jun 14, 2014 11:00 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
bps works pretty good
_________________ that's going itch when it dries
| Sat Jun 14, 2014 11:34 am |
baron von
if you dip coat the handle in plastic coat (several layers) it makes it a little nicer
| Sat Jun 14, 2014 11:45 am |
odass
Baron I like that idea maybe make it a little more comfy on those long runs
_________________ Dead Fowl Custom 1954hd with a GTR
| Sat Jun 14, 2014 12:12 pm |
Wildberry
Joined: Sun Apr 22, 2012 6:17 pm Posts: 1018 Location: DA HAVEN FL,
What's that on top of the tiller control box  New stuff everywhere these days.
_________________ EMF 16x42, 3/16 skiff, 35 GTR Stage 0
| Sat Jun 14, 2014 12:59 pm |
doubleBanded
Joined: Sun Feb 03, 2013 1:26 pm Posts: 3084 Location: Down South
How much is that bps grip
_________________ 1852 Dfou custom 35gtr
| Sat Jun 14, 2014 1:29 pm |
LA Prop
I've sold about 15 bps throttles in the last month
_________________ 20' homemade skiff with a stage 2 gtr
| Sat Jun 14, 2014 1:31 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
| Sat Jun 14, 2014 2:01 pm |
ajverret
Joined: Sun Sep 29, 2013 5:33 pm Posts: 645 Location: New Iberia, La
Will the bolt right on to the old handle or do the need to be modified
Sent from da mud hole
_________________ 1848 Uncle J and 37 EFI GTR
| Sat Jun 14, 2014 3:16 pm |
baron von
| Sat Jun 14, 2014 3:47 pm |
msm8281
You will have it down on the first trip. It still happens to me from time to time after 4 years. As far as I'm concerned it won't hurt anything. The engine will just die.
Sent from my HTC One mini using Tapatalk
| Sat Jun 14, 2014 3:52 pm |
baron von
| Sat Jun 14, 2014 4:24 pm |
LA Prop
| Sat Jun 14, 2014 5:46 pm |
LA Prop
| Sat Jun 14, 2014 5:47 pm |
LA Prop
The bps grip is 60$ with the cables or 50$ w/o the cable. And i would recommend not using the cable on the stock the s connector isn't the same size as the one for the gtr.
| Sat Jun 14, 2014 5:50 pm |
Wildberry
| Sat Jun 14, 2014 6:55 pm |
msm8281
| Sat Jun 14, 2014 7:57 pm |
baron von
if you dip coat it be sure to give it a once over with course sandpaper (I think I used 60 grit) and clean it off i used acetone. The only way I got paint to stick to the mounting without cracking really bad was put some enamel in a cup with hardner and dip it in, 2 coats I put older bolts in bolt holes and removed bolts when paint started to setup and cleaned up with razor blade. I also gave the mount a once over with course sandpaper.
now will it stick - I don't know but looks cool and has taken a few likes so far,,,
| Sat Jun 14, 2014 8:41 pm |
LA Prop
| Sat Jun 14, 2014 9:19 pm |
msm8281
Mikunis for both. For my dad's motor and mine.
| Sat Jun 14, 2014 9:21 pm |
baron von
9-10 bucks @ home depot - in paint section?
| Sun Jun 15, 2014 9:28 am |
baron von
I also noticed GT runs throttle cable close to engine - thats ok I get it - but you want your cable to have as gentle as turns as possible also, this is what I did, used 1 zip tie on fan cage and a insulated wire hold down on engine
| Sun Jun 15, 2014 9:38 am |
baron von
here is what you need 1/4 inch drill to drill out hole on wire hold, small piece of vacuum line (split on screwdiver) to fit on cable and install
| Sun Jun 15, 2014 9:43 am |
