It is currently Wed Nov 04, 2026 11:12 am
Reply to topic  [ 24 posts ]
 Boring
Post Boring
Does anyone make pistons if you were to punch out thirty thousandths or do they just make them up to twenty? Was told you can get twenty thousandths but not thirty, is this true? Been doing some searching as to where to even get the twenty thousandths but cant seem to even find that. anyone help point me in the right direction.
Is boring out that much a bad idea on an already modded motor, or just a 35 briggs in general
Im running a pro-drive with mag 45 internals, IM heads, exhaust and mikuni right now.
Burlap Brothers
Sat Jun 21, 2014 5:54 pm
Post Re: Boring
Briggs makes .020 stock pistons. There's a reason for that you're dealing with a shitty block to begin with. Theres other ways of building compression that's much safer than that.
I'm no expert but other s will agree with me.
Sent from my HTC One mini using Tapatalk
Sat Jun 21, 2014 8:05 pm
Post Re: Boring
Reason I ask is I have some scoring on one of the cylinder walls, trying to weigh my options of boring it out to clean it up vs a new block.
Burlap Brothers
Sat Jun 21, 2014 8:27 pm
Post Re: Boring
what kind of speeds are you getting? what boat are you running?
Sat Jun 21, 2014 8:39 pm
Post Re: Boring
New block if you're .020 already.
Sat Jun 21, 2014 8:40 pm
Post Re: Boring
Still at stock bore, running an 1854 pd full floation a sides and what not with basically every add on so she's heavy to say the least, running about 28mph at 4250 to 4300 light load, boat use to run 31 all day bumping 32. Been running 28 now for a few years, I thought it was the valves until we opened it up.
Burlap Brothers
Sat Jun 21, 2014 8:52 pm
Post Re: Boring
Prop....maybe
Sat Jun 21, 2014 8:54 pm
Post Boring
You can get pistons just about whatever size you want.
Sat Jun 21, 2014 9:51 pm
Post Re: Boring
Would you do..030???
Sat Jun 21, 2014 9:55 pm
Post Boring
I would if i had to, i'd try .020 before ordering pistons and see if that cleaned the cylinders up enough. Briggs gives a specific tolerance for theirs and you don't need to physically have the pistons before doing the work. If that don't clean it up, look into some other options. My machine shop guy would not charge me twice though if .020 wasnt going to work.
Sat Jun 21, 2014 9:58 pm
Post Re: Boring
Heck I ain't scared, I'll go .080
Sat Jun 21, 2014 10:01 pm
Post Re: Boring
Sat Jun 21, 2014 10:20 pm
Post Re: Boring
I wouldn't go boring anything until u have the pistons in ur hand and u can go .080
Sent from my iPhone using
Sat Jun 21, 2014 10:29 pm
Post Re: Boring
They give no skirt clearance numbers. You bore to a specific diameter. If you talk to a dealer or rep, they'll actually tell you not to give the machine shop the pistons. I'm not any kind of guru, but i do know the machine shop wants the pistons and wants the skirt clearance numbers. I've not had an issue just giving them a bore diameter though and have had more than one engine bored out.
Sat Jun 21, 2014 10:32 pm
Post Re: Boring
Can you guys point me to where I could get .030 if the .020 doesn't work? I still can't find anything on the web
Burlap Brothers
Sun Jun 22, 2014 8:40 am
Post Re: Boring
J.E. pistons will make custom pistons.
Sun Jun 22, 2014 9:09 am
Post Re: Boring
Wouldn't it be about the same price to get a new block than getting it bored and getting custom pistons made?
Sun Jun 22, 2014 9:16 am
Post Re: Boring
Sun Jun 22, 2014 9:28 am
Post Re: Boring
Boring u looking at 50$ a cylinder resleeving about a 150$ a cylinder and that's on the high side
Sun Jun 22, 2014 9:29 am
Post Re: Boring
What about custom pistons?
Sun Jun 22, 2014 9:48 am
Post Re: Boring
Custom pistons are a little on the high side. I would contact performance v twins. He's a little hard to get ahold of, but is probably going to be your best bet, unless you know exactly what you need. Pin height, etc..
Sun Jun 22, 2014 10:40 am
Post Re: Boring
Custom pistons aren't as bad as u would think but some of the company's want u to buy 4 not just 2
Sun Jun 22, 2014 11:24 am
Post Re: Boring
Also when ordering custom pistons let them know there for an air cooled engine. Some piston manufactures will require additional clearance (.001).
Sun Jun 22, 2014 12:33 pm
Post Re: Boring
Appreciate the help fellas, AKA cant thank you enough for your time.
Culprit turned out to being a compression ring failed.
Let the boring begin, hoping .020 cleans it up.
Burlap Brothers
Mon Jun 23, 2014 12:34 pm
