Getting gas from front tank to motor.... http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=54111 |
Author: | sinkey [ Fri Jun 20, 2014 8:10 am ] |
Post subject: | Getting gas from front tank to motor.... |
Anybody got any secrets after your boat has sat a month or 2? Ive never had this problem. Tank is 3/4 full, and I pumped that bulb for an hour yesterday, closed vent and open, neither would get it flowing. Any help would be appreciated! I hate even asking this, but never had this problem. Thanks |
Author: | baron von [ Fri Jun 20, 2014 8:15 am ] |
Post subject: | Re: Getting gas from front tank to motor.... |
1. Check tank vent – working properly 2. Check fuel pick up tube & screen in tank 3. Check fuel lines & filter for obstructions and collapsed/kinked lines 4. Check for any leaks in fuel line connections – leaks won’t always leak fuel but will allow air into lines 5. Seek professional help |
Author: | sinkey [ Fri Jun 20, 2014 8:26 am ] |
Lol. Thanks buddy. |
Author: | Swamper01 [ Fri Jun 20, 2014 8:36 am ] |
I had this problem yesterday too lol |
Author: | Smoke [ Fri Jun 20, 2014 10:45 am ] |
Author: | BayouBuster [ Fri Jun 20, 2014 10:50 am ] |
Check yo make sure the pickup tube didn't fall off. Mine fell off going across the lake one day and was a booger to fish out. |
Author: | baron von [ Fri Jun 20, 2014 12:04 pm ] |
Author: | SETx Longtail [ Sun Jun 22, 2014 5:52 pm ] |
It also tastes great after trying to pull a siphon on a tank... With a Miller Lite chaser of course ![]() |
Author: | Russ [ Sun Jun 22, 2014 6:09 pm ] |
Pull line from carb, put your finger over it while you pump remove it every 5-10 for a couple, then put back. Should do the trick. If not, could be something a bit more involved that was mentioned already. This was all it took for mine to get primed. Wouldn't work any other way. |
Author: | sinkey [ Mon Jun 23, 2014 8:25 am ] |
Figured it out. Back tracked from motor and found a loose fitting by the tank. Tightened it up, and good to go. Thanks for the help. Kind of made me feel like an idiot! ![]() |
Author: | baron von [ Mon Jun 23, 2014 11:48 am ] |
Author: | NORTHFLORIDAFOWLER [ Mon Jun 23, 2014 12:14 pm ] |
electric fuel pump!!!!! |
