It is currently Wed Nov 04, 2026 8:02 am
Reply to topic  [ 12 posts ]
 Getting gas from front tank to motor....
Post Getting gas from front tank to motor....
Anybody got any secrets after your boat has sat a month or 2?
Ive never had this problem. Tank is 3/4 full, and I pumped that bulb for an hour yesterday, closed vent and open, neither would get it flowing.
Any help would be appreciated! I hate even asking this, but never had this problem.
Thanks
Fri Jun 20, 2014 8:10 am
Post Re: Getting gas from front tank to motor....
1. Check tank vent – working properly
2. Check fuel pick up tube & screen in tank
3. Check fuel lines & filter for obstructions and collapsed/kinked lines
4. Check for any leaks in fuel line connections – leaks won’t always leak fuel but will allow air into lines
5. Seek professional help
Fri Jun 20, 2014 8:15 am
Lol. Thanks buddy.
Fri Jun 20, 2014 8:26 am
I had this problem yesterday too lol
18x40 skiff/35 hp GTR
Fri Jun 20, 2014 8:36 am
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Fri Jun 20, 2014 10:45 am
Check yo make sure the pickup tube didn't fall off. Mine fell off going across the lake one day and was a booger to fish out.
Fri Jun 20, 2014 10:50 am
Fri Jun 20, 2014 12:04 pm
It also tastes great after trying to pull a siphon on a tank... With a Miller Lite chaser of course :lol:
-Custom pool noodle
-stage 4 water wings
Sun Jun 22, 2014 5:52 pm
Pull line from carb, put your finger over it while you pump remove it every 5-10 for a couple, then put back. Should do the trick. If not, could be something a bit more involved that was mentioned already. This was all it took for mine to get primed. Wouldn't work any other way.
Sun Jun 22, 2014 6:09 pm
Figured it out. Back tracked from motor and found a loose fitting by the tank. Tightened it up, and good to go.
Thanks for the help. Kind of made me feel like an idiot! :lol:
Mon Jun 23, 2014 8:25 am
Mon Jun 23, 2014 11:48 am
electric fuel pump!!!!!
Mon Jun 23, 2014 12:14 pm
