Headwork http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=55114 |
Page 1 of 2 |
Author: | Kdew05 [ Fri Jul 25, 2014 5:20 pm ] |
Post subject: | Headwork |
Does anyone know of anyone who does head work near laurel, ms? Looking to do a little tuning to her before season creeps in... |
Author: | mizzippi jb [ Fri Jul 25, 2014 5:27 pm ] |
Post subject: | Re: Headwork |
Send them to Jamie b along with your intake. Thank me later. |
Author: | pokey79 [ Fri Jul 25, 2014 5:36 pm ] |
Catch him soon before the doors close for hunting season! |
Author: | deadbird8 [ Fri Jul 25, 2014 6:36 pm ] |
Author: | Kdew05 [ Fri Aug 01, 2014 11:49 am ] |
Sending them to LA prop to put his magic touch on them then gettin mikuni from Andy in a month.... Hoping to see a load carying improvement |
Author: | Mudmotor Slayer [ Fri Aug 01, 2014 7:24 pm ] |
Author: | Mudmotor Slayer [ Fri Aug 01, 2014 7:25 pm ] |
Author: | Kdew05 [ Mon Aug 11, 2014 10:01 am ] |
I know someone on here has got just headwork and exhaust done... Eventually I want to add mikuni but what speeds, load should I expect to see out of it without the carb? I was getting 26 consistent bump 27 with light load and 2 person load on a 1746 gtb... |
Author: | cupped up [ Mon Aug 11, 2014 10:19 am ] |
28 bumping 29 and more bottom end. Don't expect a lot of speed gain, you're not doing anything to compliment the head work. I.E. Carb/cam |
Author: | basinhunter2012 [ Mon Aug 11, 2014 10:51 am ] |
i had heads cam exhaust on a 1746..gained alot of speed after adding the carb..its high as giraffe puss but you should see good gains from it |
Author: | mudxxed [ Mon Aug 11, 2014 10:54 am ] |
couldnt run a stock carb ever again after getting the mikuni. Honestly, id rather get a carb first before headwork. You just cant run these motors correctly with the governor linkage systems. Honestly dont know why MM manufactures even let a motor out of the shop with the crap briggs carbs. Add the carb into the costs of a new motor.... That carb is meant to be ran at a constant 3600 rpms. Not between 800-4300 |
Author: | MarshJB [ Mon Aug 11, 2014 11:18 am ] |
Author: | mudxxed [ Mon Aug 11, 2014 11:30 am ] |
I never had starting or idling issues either on mine and it STILL is night and day with throttle response |
Author: | dixieducker [ Mon Aug 11, 2014 11:32 am ] |
Author: | MarshJB [ Mon Aug 11, 2014 11:58 am ] |
Author: | MarshJB [ Mon Aug 11, 2014 11:59 am ] |
Author: | Kdew05 [ Mon Aug 11, 2014 12:35 pm ] |
I figured 28-29ish until the carb was added, just have to wait a minute for the carb... Just got married and that chit ain't cheap ha... |
Author: | cupped up [ Mon Aug 11, 2014 3:05 pm ] |
Author: | msm8281 [ Mon Aug 11, 2014 4:59 pm ] |
To haul big ass!! |
Author: | Kdew05 [ Mon Aug 11, 2014 5:15 pm ] |
Any break in issues or things to keep in mind once I put my heads back on motor? Also, any cheap tricks or adjustments to get a little more hp besides the carb/cam? Will I create any issues with this headwork done and not changing coils or rev limiter for any reason? I've caught the mod my motor itch and can't stop it.... |
Author: | banded-mallard [ Wed Aug 13, 2014 4:58 am ] |
Author: | Kdew05 [ Wed Aug 13, 2014 5:26 am ] |
Yes I do, I have bps q exhaust... I have a mud buddy hd 3500 on a gtr boat... Don't chastise me, that's how it was when I bought it on a good deal so I said what the heck... |
Author: | banded-mallard [ Wed Aug 13, 2014 5:39 am ] |
Author: | Kdew05 [ Wed Aug 13, 2014 5:01 pm ] |
How will I know if I have 4350 coils or 4700? From what I've seen, they switched midstream in 2012, which is when my motor was manufactured but classified as 2013 when sold... |
Author: | mudxxed [ Wed Aug 13, 2014 5:08 pm ] |
Rev outta water and see what it hits. 4350 or 4700. That's what coils you got. |
Author: | Kdew05 [ Wed Aug 13, 2014 5:17 pm ] |
Too simple... Make it sound more extensive next time, thsnks |
Author: | deadbird8 [ Thu Aug 14, 2014 6:08 am ] |
Author: | Kdew05 [ Thu Aug 14, 2014 5:57 pm ] |
Marsh jb, what are your specs on your setup and speeds? if you are running heads and exhaust with stock carb, I'd like a comparison with the same mods unless you have other work done... |
Author: | MarshJB [ Thu Aug 14, 2014 6:01 pm ] |
.040 heads, hoyt mild cam, mm baffled. My boat runs 30-31 all day long. Four people runs 26-28 depending on how fat everyone is. |
Author: | Kdew05 [ Thu Aug 14, 2014 6:37 pm ] |
Dang... That'd be nice, what are your boat dimensions? |
Author: | MarshJB [ Thu Aug 14, 2014 6:43 pm ] |
17x54 extreme gt boat |
Author: | Kdew05 [ Sat Aug 16, 2014 1:17 am ] |
So I just got her all back together, and back off the water to give the review of the headwork done... All I can say is that it took some time to get it all pieced back together, short of a valve gasket, it's back together, going to get that tomorrow. Awesome work LA prop, you da man ha. By myself 2 batteries tank of gas trolling motor and yeti rolled 30 consistent, me and a buddy stayed 29 the whole time, unfortunately tach went out but putting new one on tomorrow as well. But the get up and go is a drastic change as well. thank you and if anyone needs headwork LA prop is the guy... Great guy to deal with... Noticed my crank case gasket might have a small leak but going to tighten bolts up and hopefully it will hold up for a little while longer. |
Author: | Kdew05 [ Sat Aug 16, 2014 5:12 pm ] |
I am adjusting the idle rpm to sit around 1100 I think is a sweet spot, but while adjusting the idle screw in the front I realized it was all the way backed out and not coming down any more. My rpm at that time was around 1800 on idle. I then adjusted the screw with spring on the backside of the carb to allow the springs to retract more for the front idle screw in the front of the motor. I am unsure if this is the proper way to make your idle arm hit the front screw because it was sticking, just making sure that's what that back screw with the spring is for on the back of the carb. It's all got tons of slack in it. can't wait to throw it away for the mikuni |
Author: | AKA Freshwaterkilla [ Sat Aug 16, 2014 5:43 pm ] |
Idle at 1100 good lawd u must have some really fat chicks riding with u to slow it down while putting it back on the trailer Sent from my iPhone using |
Author: | bayouboy [ Sat Aug 16, 2014 5:48 pm ] |
Author: | Kdew05 [ Sat Aug 16, 2014 6:33 pm ] |
Ha what is your suggestion aka? |
Author: | AKA Freshwaterkilla [ Sat Aug 16, 2014 6:48 pm ] |
Mikuni. ![]() Sent from my iPhone using |
Author: | mudxxed [ Sat Aug 16, 2014 9:05 pm ] |
Sonerhing is hanging up or sticking. Is your spring allowing the arm to return all the way to idle? |
Page 1 of 2 | All times are UTC - 6 hours |
