bayouboy35
 Gator tail issue
Have a stage 2 gator tail. Engine bogs when juice on throttle from idle. Engine idles fine any ideas on what causes this?
Wed Aug 27, 2014 7:54 pm |
odass
 Re: Gator tail issue
Probably the acc pump, or other carb issue, normally on a car ,id say timing, but no real adjustment there lol
_________________ Dead Fowl Custom 1954hd with a GTR
Wed Aug 27, 2014 8:04 pm |
bayouboy35
I adjusted the acc pump both ways and still the same thing. I am running a 162.5 main jet. Would that have any effect on this?
Wed Aug 27, 2014 8:07 pm |
odass
Wed Aug 27, 2014 8:10 pm |
bayouboy35
I did notice when I would pull the choke out it wouldn't big down.
Wed Aug 27, 2014 8:14 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Wed Aug 27, 2014 8:29 pm |
bayouboy35
Just filled tanks up today
Wed Aug 27, 2014 8:33 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Did you visually check the accelerator pump nozzle to see if its squirting down the carbs throat? Did you remove the carb bowl and check the float and jets?
Wed Aug 27, 2014 9:13 pm |
bayouboy35
Yes I seen the accelerator pump squirting fuel in the carb. I have not taken the carb apart yet to visually inspect it.
Thu Aug 28, 2014 5:07 am |
Will
Too much air and not enough gas is what's causing it. Make sure the pump is hitting the second you touch it but in reality the acc pump just helps, the rest needs to be tuned right first. Gotta get in there and see what's inside.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Thu Aug 28, 2014 7:31 am |
bayouboy35
As far as tuned just right where do I start inside the carb?
Thu Aug 28, 2014 7:41 am |
bayouboy35
And is the set screw for the pump suppose to be touching at idle?
Thu Aug 28, 2014 7:42 am |
Will
Thu Aug 28, 2014 7:45 am |
Tulsa_Woody
Joined: Wed Jan 14, 2009 8:31 am Posts: 428 Location: Tulsa, OK...Cajun by Marriage
Hold the phone!! This happened to me and it is a very simple...there is a screw that is supposed to keep the choke set at a certain level...after time, the vibration of the motor can allow that screw to rotate and then your engine will be down to a low idle but when you give it throttle, it bogs/chokes itself out. Pull out your choke slightly and adjust that little screw down toward the motor so that the choke stays out slightly, then give it throttle and see what happens. That is what has happened to mine, and more than once. Woody
_________________ 17x54 Gator-Tail w/ 35HP GTR Gator-tail/MM exhaust Center Console...it fixes tiller torque viewtopic.php?f=4&t=9330
Thu Aug 28, 2014 12:30 pm |
bayouboy
Thu Aug 28, 2014 4:53 pm |
Tulsa_Woody
Yes, stock carb and linkage...if you can pull the choke out slightly and motor runs better, then check that nut around ckoke...going to my camp this weekend to get my rig...i'll take dome pics! Woody
Thu Aug 28, 2014 9:16 pm |
