Stock 35 hp jets http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=56164 |
Author: | Puddler45 [ Fri Aug 29, 2014 5:33 pm ] |
Post subject: | Stock 35 hp jets |
Does anyone have spare jets for a 35 briggs carb. I m running too lean with my setup with heads and exhaust on a 23 and now im bout too install a cam this weekend. Running lean on a 138 144 anything fatter than that would work. I have a 148, 152 on order but last time it took over a month from the dealer and duck season is only bout a month away. Im sure a 152, 158 would be little rich but get me outta a jam. Let me know what ya got and how much u want for em. Carb model is 845074 but I would think the jets are interchangeable. |
Author: | AKA Freshwaterkilla [ Fri Aug 29, 2014 7:07 pm ] |
Post subject: | Re: Stock 35 hp jets |
Buy a mikuni and be done quit messing with that junk Sent from my iPhone using |
Author: | Puddler45 [ Fri Aug 29, 2014 7:24 pm ] |
Its almost there just gotta fatten up the jets and it will run well for less than 1/4 the price. Someone's gotta have a carb laying around that they took off to install a mikuni. Im a cheap fucker lol |
Author: | baron von [ Fri Aug 29, 2014 7:29 pm ] |
I got everything for a Oct 2013 35hp horizontal- carb, manifold, linkage, fuel pump ect ect ect - with 4 minutes on it. whats it worth? |
Author: | Puddler45 [ Fri Aug 29, 2014 8:32 pm ] |
Do you have the 152, 158 jets give ya $20 bucks for the 2 of em. Or if u wanna borrow em to me for a month or so till I get the other ones in let me know what ya think. Just want to get out scouting before the season starts. |
Author: | Puddler45 [ Fri Aug 29, 2014 8:42 pm ] |
I have other jet sizes I can trade you that way you could sell the carb set up complete if ya wanted |
Author: | baron von [ Fri Aug 29, 2014 9:15 pm ] |
are they marked - how do you tell? |
Author: | Puddler45 [ Fri Aug 29, 2014 9:19 pm ] |
They are stamped on the jet unscrew the 4 screws on the bowl underside of carb. Pilot jet should be marked 50 or 52 main jets will be marked anywhere from 130s to 150s depending. Most stock carbs come with 152 158 but also came with 138, 144. |
Author: | deadbird8 [ Sat Aug 30, 2014 4:15 am ] |
The main jets are in the bottom of the carb bowl and are different depending on which cylinder they feed. Old 35HP's came with 142/148, newer ones come with 138/144, not sure if they are interchangeable with a 23hp or not. |
Author: | Puddler45 [ Sat Aug 30, 2014 6:40 am ] |
I have a 35 hp carb on my 23. Runs a little lean with the 138, 144. I have 148, 152 jets on order |
Author: | baron von [ Sat Aug 30, 2014 7:01 am ] |
he' right (again) mine has 138 - 144 |
