It is currently Fri Jul 04, 2025 7:26 pm
Reply to topic  [ 3 posts ]
 Oil Leak
Post Oil Leak
oil leak on 5500 sport v. 22 hrs on the motor, best option to prevent future issue or is there any competent person on here that has knowledge of actually running the motors and not reading biased reviews? replacing the crank case gasket and o rings now just not sure if its an often occurring issue
35hp Mud Buddy Stage 1 pushing 15x44 Gator Trax W / Hunt Deck
Sun Dec 07, 2014 9:46 pm
Post Re: Oil Leak
Where is it leaking? It's just a Briggs block like any other motor. Change a gasket. 22hrs??? Should still be under warranty.
Sun Dec 07, 2014 11:29 pm
Post Re: Oil Leak
The 5500 V seems to have a vibration issue that causes the crankcase bolts to loosen. It happens on most motors, but seems more of a problem on your setup. Mark the bolts after u have changed the gasket with a paint marker so you can easily look at them and verify none are backing off.
18'x54"CC Hanko/ 36PD
Tue Dec 09, 2014 7:31 am
Users browsing this forum: No registered users and 114 guests
