It is currently Mon Jun 30, 2025 6:47 pm
Reply to topic  [ 38 posts ]
 Perf V Twins: Al Hodge
Post Perf V Twins: Al Hodge
So I spoke to Al last week and he seems like a real stand up guy. I told him what I wanted to get out of my GTR and he recommended his 45 kit which consists of this.
PVT BB piston/rod set
PVT BB cam/lifter set
PVT roller rocker set
PVT BB pushrod set w/shims
PVT Manley Race Master valve set
My question is...Is there anyone in the Orlando area who knows what they are doing and can do this rebuild for me? I won't be getting the parts until after Christmas.
-J
Sun Dec 21, 2014 5:29 pm
Post Re: Perf V Twins: Al Hodge
Its not that really hard to do it yourself or if you have a buddy that knows their way around a motor. These engines are pretty simple.
I'd advise that you have your heads done while you have them off for the valve and shim install.
Also, if you have CDI coils, get the high rev 4700 RPM set. And depending on what you have now, you need to upgrade your governor spring (like the MB 45 spring) to allow higher RPM operation. While you have the case cover off, you may also install the stud/sleeve kit from BoatDr. BoatDr could sell you all of the upgrade parts and headwork as well.
Sun Dec 21, 2014 7:12 pm
Just out of curiosity did he quote you a price for all that?
Mon Dec 22, 2014 11:42 am
@deadbird...Thanks for the info. I have a 2013 so I believe I will be ok with the CDI coils. He is also going to port and polish for me.
@bassmastercia...here is what he quoted me on for the 45 Kit:
The kit is as follows:
PVT BB piston/rod set............................$495.00
PVT BB cam/lifter set.............................$235.00
PVT roller rocker set...............................$325.00
PVT BB pushrod set w/shims.................$70.00
PVT Manley Race Master valve set.........$140.00
Pro Flow Port & Polish............................$250
-J
Mon Dec 22, 2014 7:29 pm
Talk to Sid at fast duck motors he knows his way around em pretty good.
<"({{{}<< 1854 Prodigy CC
Mon Dec 22, 2014 9:38 pm
I sent my powerhead to Al a couple of years ago. He is the real deal. He did a great job on mine.
Mon Dec 22, 2014 11:36 pm
Tue Dec 23, 2014 3:51 am
im just going off of info I read on here so somebody correct me if I'm wrong. I believe PVT builds compression with their Pistons, not by decking. Decking changes the angle of the pushrods a little and changes the "valve train geometry" slightly. Whatever that means.
Tue Dec 23, 2014 11:53 am
Tue Dec 23, 2014 12:19 pm
-J
Tue Dec 23, 2014 2:10 pm
Wed Dec 24, 2014 7:28 am
Like I said before im just going on what I've read on here. But doesn't pvt build race cart engines that may well turn 7-8 grand for short periods of time? just trying to figure out why one builder won't deck, and all the others do...?
Wed Dec 24, 2014 11:26 am
He will deck them if that is what you want. I know quite a few people who've had their heads decked at PVT. He prefers to build compression with pistons/rods, which I would prefer too, but it's a lot more expensive to do it that way. The heads are going to be worked anyway, decking only adds 100 bucks or so, pistons/rods is usually over 500 bucks. Both accomplish higher compression, pistons do it with more quench area which should yield a better performing motor. 4-500 dollars better is up to you. Everyone has their own way of doing things. You talk to as many as you can and do what you think is best.
Wed Dec 24, 2014 11:37 am
GTR, Waitin' on a DFOU hull
Wed Dec 24, 2014 12:35 pm
Thu Dec 25, 2014 4:50 am
where in orlando are you located you can do the work your self i have rebuilt a couple of these motors there pretty simple if you need a hand let me know
1648 G3 2013 mudbuddy 35
Thu Dec 25, 2014 6:11 am
@deadbird- Man, thank you so much for the info. It really put things into perspective for me. Great info. I'm not sure if I'm getting flat top pistons. I think it would be wise for me to find out.
@chevy01- I'm live in SW Orlando., Dr Phillips area. You guys are tempting me to crack this joker open myself. Is this a one day job or a few days?
-J
Thu Dec 25, 2014 8:30 am
it would only be a one day job im a technician for ford so if you need a hand i have all the tools im rebuilding a 23 kohlor in my garage right now and about to tear the heads off my 35 mb to send to the boat dr. i live in orlando
Thu Dec 25, 2014 9:00 pm
Nice. I will be giving you a call when the parts arrive. Thanks.
-J
Fri Dec 26, 2014 6:17 am
Fri Dec 26, 2014 6:22 am
-J
Fri Dec 26, 2014 7:31 am
That's where I'm at I'm taking mine apart this coming Friday to send my heads off so I won't have a boat for a week or so but my buddy has his new rig now so I will be able to hunt still
Fri Dec 26, 2014 8:00 am
More than welcome to hit me up any time we are always riding some where. St. John's or cypress
Fri Dec 26, 2014 8:03 am
-J
Fri Dec 26, 2014 8:30 am
Oh yea we have been hunting every weekend. Been trying to find a decent wood duck hole but no luck so far
Fri Dec 26, 2014 8:56 am
-J
Fri Dec 26, 2014 1:41 pm
Sun Dec 28, 2014 3:16 pm
I'd advise to get rid of the debris screen on the front when you put it back together.
Sun Dec 28, 2014 3:37 pm
I seen the 2014s don't have it. Why is that better airflow?
Sun Dec 28, 2014 3:40 pm
Sun Dec 28, 2014 4:05 pm
I sent my motor to him and he did a great job . I had the 45 kit put on . Ran 22 before and 31-32 after.
Sun Dec 28, 2014 6:06 pm
Sun Dec 28, 2014 6:39 pm
awesome thanks for the info
Sun Dec 28, 2014 6:53 pm
-J
Sun Dec 28, 2014 9:13 pm
I would leave stock pushrods just a suggestion seen lots of torn up heads . Shit happens I'd rather bend a pushrods than crack a head.
Sun Dec 28, 2014 9:36 pm
You think it's possible to make these Pistons fit lol
Sun Dec 28, 2014 9:42 pm
Good luck with that. Lol.
BTW, we are hunting on Thursday. You're more than welcome to join us.
-J
Sun Dec 28, 2014 10:19 pm
Sounds good I will hit you up this week
Mon Dec 29, 2014 5:37 am
Users browsing this forum: Google [Bot] and 147 guests
