Scalestalker
 Mud buddy 7000 oil and filter?
I recently purchased a mud buddy 7000 with 35 hours on it. The oil is dirty and to the add mark so I figure I'll give her an oil change. What oil and filter is recommended for it? I will be running it in temps from 20s-90s
Sat Dec 27, 2014 3:42 pm |
Kcpanages
 Re: Mud buddy 7000 oil and filter?
5w-30 MOBIL-1 I use vanguard filter, I have a hard time finding the Fram filter
Sat Dec 27, 2014 4:22 pm |
50fps
Most any oil will work fine, but an oil with high zinc and designed for an air cooled engine is a good route to go. Napa, Wix, Carquest, anything along those lines in a filter. Here is a good read. http://speedtalk.com/forum/viewtopic.php?t=30483
Sat Dec 27, 2014 6:24 pm |
lunacris
Joined: Thu Mar 29, 2012 8:31 pm Posts: 3251 Location: Da Parish
_________________ GatorHide - MB
Sat Dec 27, 2014 6:26 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
The briggs and stratton oil filters have a high temp check valve in them for the Vanguard engines
Others will know if there are other brands that do so (and what your 7000 would need).
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Sat Dec 27, 2014 6:50 pm |
cb5331
The wix does
Sat Dec 27, 2014 6:55 pm |
Prodigy
Check the valves
check the valves
check the valves
and make sure all the crank case bolts stay tight
champion rc12yc plugs gapped at 35 Amsoil is good oil also Briggs Filter
and check the valves
also run 93 octane.....nothing less..........
_________________ Prodigy Boats https://www.facebook.com/Prodigyboats www.prodigyboats.com Contact for info - http://prodigyboats.com/contact-us/ 706-253-7766
Sat Dec 27, 2014 11:28 pm |
Scalestalker
Mon Dec 29, 2014 5:42 am |
Scalestalker
Mon Dec 29, 2014 5:43 am |
50fps
Mon Dec 29, 2014 7:36 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
Run 93 whether it has ethanol or not.
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Mon Dec 29, 2014 7:43 am |
