It is currently Mon Jun 30, 2025 2:05 pm
Reply to topic  [ 4 posts ]
 previous 23 HP briggs fuel problem
Post previous 23 HP briggs fuel problem
I posted earlier of my 23 briggs / mikuni fuel problem. I've diagnosed to the motor receiving too much fuel. After several hours, the plugs fail. They are wet when I check after changing and running a little bit.
Can someone give me a run-down of possible causes for this, so I can go through the motor?
I checked the valve clearances yesterday to ensure they were still tight and correct, and made a minor adjustment.
Also, I believe the throttle cable is correct, as it is closed fully within the carb when idling.
My fuel / air mix screw on the carb seems to need to be turned way out for the motor to idle correctly. I know the factory setting is like 1 1/2 turns, but, at that setting, my motor is revving really high. I need to back it out another couple full turns to get it to rev down. That seems weird...
Any suggestions?
Sat Dec 27, 2014 3:11 am
Post Re: previous 23 HP briggs fuel problem
Re jet to a smaller size?
Sat Dec 27, 2014 4:47 am
Sat Dec 27, 2014 9:28 am
It should idle fine at 1.5 to 1.75 turns out, set the idle there (engine warmed for 5 mins). If not, you have another problem and should check the idle jet and float. You tune the Mikuni carb from idle up to WOT.
Sat Dec 27, 2014 10:46 am
Users browsing this forum: No registered users and 164 guests
