Mud buddy 7000 oil and filter? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=58945 |
Author: | Scalestalker [ Sat Dec 27, 2014 3:42 pm ] |
Post subject: | Mud buddy 7000 oil and filter? |
I recently purchased a mud buddy 7000 with 35 hours on it. The oil is dirty and to the add mark so I figure I'll give her an oil change. What oil and filter is recommended for it? I will be running it in temps from 20s-90s |
Author: | Kcpanages [ Sat Dec 27, 2014 4:22 pm ] |
Post subject: | Re: Mud buddy 7000 oil and filter? |
5w-30 MOBIL-1 I use vanguard filter, I have a hard time finding the Fram filter Sent from my iPhone using Tapatalk |
Author: | 50fps [ Sat Dec 27, 2014 6:24 pm ] |
Most any oil will work fine, but an oil with high zinc and designed for an air cooled engine is a good route to go. Napa, Wix, Carquest, anything along those lines in a filter. Here is a good read. http://speedtalk.com/forum/viewtopic.php?t=30483 |
Author: | lunacris [ Sat Dec 27, 2014 6:26 pm ] |
Author: | MNGunner [ Sat Dec 27, 2014 6:50 pm ] |
The briggs and stratton oil filters have a high temp check valve in them for the Vanguard engines Others will know if there are other brands that do so (and what your 7000 would need). |
Author: | cb5331 [ Sat Dec 27, 2014 6:55 pm ] |
The wix does |
Author: | Prodigy [ Sat Dec 27, 2014 11:28 pm ] |
Check the valves check the valves check the valves and make sure all the crank case bolts stay tight champion rc12yc plugs gapped at 35 Amsoil is good oil also Briggs Filter and check the valves also run 93 octane.....nothing less.......... |
Author: | Scalestalker [ Mon Dec 29, 2014 5:42 am ] |
Author: | Scalestalker [ Mon Dec 29, 2014 5:43 am ] |
Author: | 50fps [ Mon Dec 29, 2014 7:36 am ] |
Author: | DmaxHunter [ Mon Dec 29, 2014 7:43 am ] |
Run 93 whether it has ethanol or not. |
