It is currently Thu Aug 20, 2026 11:41 am
Reply to topic  [ 24 posts ]
 Prodrive newbie
Post Prodrive newbie
Well to start I picked up a 04 prodrive with 183hrs on it. Looks in a little rough shape but seems to run and sound solid. The lower unit is leaking (I knew that when I bought). Seller apparently had it checked over by a dealer and it checked out other then seal leak. The guy I bought it off of did throw In the 2 lower seals and the upper. First question do you think I should replace the upper right away or just the lower seal? Also when I picked it up the reverse seemed to work decent in the shop but today at home seems to work like chit and have to hold it with my foot to get it to ratchet around. The grease is thick and sticky would that keep it from working properly or do I have a bigger issue? I'm new to these being I've only run long tails.
Sun Mar 01, 2015 5:47 pm
Post Re: Prodrive newbie
Few more pics didn't up load
Sun Mar 01, 2015 6:00 pm
Doesn't that knob on the lower part of the engine hold tension for the manual reverse to ratchet?? Tried snugging it up some?
Sun Mar 01, 2015 7:26 pm
Did that still moves with the power head but a lot harder. Gotta push it over with my foot then it will ratchet once or twice and have to kick it again.
Sun Mar 01, 2015 10:09 pm
How does it work in the water? If that's how it works in the trailer, how much does that really matter?
Sun Mar 01, 2015 10:14 pm
No idea how it works in the water we have 20" of hard water on top of the lakes right now. Lol just concerned cause videos the lower unit is just suppose to spin around. I don't think this motor was maintained to well which drives me crazy cause I'm OCD about maintaining my gear for hunting
Sun Mar 01, 2015 10:23 pm
Clean old grease out and re grease. How cold is it where you are at?
1848 GTB, 36 PD w/ FPR
Mon Mar 02, 2015 8:22 pm
Maybe 10 degrees at night 25-30 during the day. The old grease is thick like honey. Also there is lower unit fluid that came out by the clutch housing the last time the guy hunted with it. Is this normal with a bad seal?
Mon Mar 02, 2015 8:57 pm
I would call pro drive and see what KP says. Best to get info from them.
Wed Mar 04, 2015 7:28 pm
A unit that old would benefit from pulling the powerhead and removing the reverse assembly and cleaning out all of the old grease.
Wed Mar 04, 2015 7:36 pm
Wed Mar 04, 2015 10:59 pm
Do yourself a favor and send the lower half of the lower unit back and let them convert it to a grease filled lower. Not out the box expensive and worth every penny.
1648 gd hull flying in front of a stage 3 with fpr
Wed Mar 04, 2015 11:09 pm
^ sounds like a good idea. Or get a gator tail lol
Thu Mar 05, 2015 6:14 am
I'm gonna replace the reverse pin good chance that it is just worn out. Gatortails are nice motors but I guess I'm partial to prodrive.
Thu Mar 05, 2015 8:12 am
I have nothing against pro-drive. I just prefer the instant reverse. There both good mud motors. Let us know how everything works out.
Thu Mar 05, 2015 8:31 am
Yes the grease conversion would be a good idea if you plan to keep the motor for a little while.
Thu Mar 05, 2015 8:32 am
Thu Mar 05, 2015 8:56 am
If it were me, to make sure it get professionally done, bring to to pro drive and tell them you want a complete maintenance overhaul. It will come back like new
Sent from my SAMSUNG-SM-N900A using Tapatalk
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Thu Mar 05, 2015 9:32 am
Thu Mar 05, 2015 10:26 am
Thu Mar 05, 2015 10:37 am
Figured since its a balmy 8 degrees and I'm off I might as well go to pound town on her. Highly not recommended lifting the power head off by hand by yourself.... I'm gonna go dig for my nuts in the snow now pretty sure they blew off!
Thu Mar 05, 2015 11:54 am
Cool stickers
Thu Mar 05, 2015 12:19 pm
Thu Mar 05, 2015 12:37 pm
Thu Mar 05, 2015 12:39 pm
