| valve lash http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=60645 |
| Author: | longlakesd [ Sun Mar 08, 2015 10:37 am ] |
| Post subject: | valve lash |
How often should it be checked? 35hp gdsd 2013 |
| Author: | Kja0792 [ Sun Mar 08, 2015 10:39 am ] |
| Post subject: | Re: valve lash |
Everytime u change the oill |
| Author: | DmaxHunter [ Sun Mar 08, 2015 11:17 am ] |
^^^ good habit to get into |
| Author: | longlakesd [ Sun Mar 08, 2015 2:15 pm ] |
When checking valves the briggs manual states that first you must set cylinder 1 valve 6 mm past TDC compression stroke .... what does this mean exactly |
| Author: | 270Handiman [ Sun Mar 08, 2015 3:04 pm ] |
Means put #1 at 1/4" past TDC on comp stroke prior to setting that side. Same on #2. |
| Author: | DmaxHunter [ Sun Mar 08, 2015 4:56 pm ] |
You can also open valve cover, turn motor over by hand, ie wrench on prop nut. Watch the rockers as you turn over, one will cycle then the other. Turn slightly more until you can feel the play in both rockers. They can both be adjusted now. You can also put a wooden dowel into cylinder and watch until it starts back down off of top dead center. |
| Author: | Kja0792 [ Sun Mar 08, 2015 7:00 pm ] |
| Author: | OwenDickeson [ Sun Mar 08, 2015 7:03 pm ] |
http://youtu.be/Iko2izttNkE Set them this way longlakesd. |
| Author: | Kja0792 [ Sun Mar 08, 2015 7:07 pm ] |
| Author: | SETx Longtail [ Sun Mar 08, 2015 7:08 pm ] |
| Author: | Kja0792 [ Sun Mar 08, 2015 7:11 pm ] |
| Author: | cb5331 [ Sun Mar 08, 2015 7:14 pm ] |
| Author: | SETx Longtail [ Sun Mar 08, 2015 7:20 pm ] |
That's the way I set valves on every 4 stroke engine I've ever touched. TDC compression. Easy to hit with the plugs out with a wooden dowel or a screwdriver if you're careful. Roll it up, set both rockers, move to the other side. |
| Author: | SETx Longtail [ Sun Mar 08, 2015 7:21 pm ] |
| Author: | cb5331 [ Sun Mar 08, 2015 7:29 pm ] |
| Author: | SETx Longtail [ Sun Mar 08, 2015 7:33 pm ] |
hey, fair enough |
| Author: | Kcpanages [ Sun Mar 08, 2015 8:26 pm ] |
| Author: | Kcpanages [ Sun Mar 08, 2015 8:27 pm ] |
| Author: | cb5331 [ Sun Mar 08, 2015 8:52 pm ] |
| Author: | Kcpanages [ Sun Mar 08, 2015 9:05 pm ] |
aka new 45hp crank! Hand made! 50+ mph Sent from my iPhone using Tapatalk |
| Author: | msm8281 [ Sun Mar 08, 2015 9:11 pm ] |
| Author: | cb5331 [ Sun Mar 08, 2015 9:12 pm ] |
That or smoking crack.. |
| Author: | Kcpanages [ Sun Mar 08, 2015 9:15 pm ] |
| Author: | Kcpanages [ Sun Mar 08, 2015 9:18 pm ] |
hmmm, what should I do? Sent from my iPhone using Tapatalk |
| Author: | 270Handiman [ Sun Mar 08, 2015 9:28 pm ] |
| Author: | cb5331 [ Sun Mar 08, 2015 9:32 pm ] |
Go stand out in front of the police station and wave that thing around. |
| Author: | Kcpanages [ Sun Mar 08, 2015 9:51 pm ] |
| Author: | Kja0792 [ Sun Mar 08, 2015 9:57 pm ] |
| Author: | Kcpanages [ Sun Mar 08, 2015 10:05 pm ] |
| Author: | longlakesd [ Mon Mar 09, 2015 6:30 am ] |
| Author: | Kja0792 [ Mon Mar 09, 2015 6:36 am ] |
No watch the video again |
| Author: | baron von [ Mon Mar 09, 2015 6:40 am ] |
it's easier with 2 guys the first couple times you do it |
| Author: | cb5331 [ Mon Mar 09, 2015 11:28 am ] |
| Author: | mudxxed [ Mon Mar 09, 2015 12:50 pm ] |
| Author: | baron von [ Mon Mar 09, 2015 1:20 pm ] |
