| DIY Mikuni kit http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=61274 |
Page 1 of 2 |
| Author: | steinb3rg [ Tue Apr 14, 2015 5:41 am ] |
| Post subject: | DIY Mikuni kit |
Just a heads up. Amazon has the Mikuni HSR42 easy kits for $288.92. (the kit came with a 20 and 25 pilot and also a 160 and 165 main) http://www.amazon.com/Mikuni-Easy-Kit-4 ... kuni+42-18 I've been building my own carb kit to come out cheaper than purchasing a premade kit. Carb - $288 2.3 Needle and Seat - $23 Cables - $7 (walmart) PVT Intake adapter - $100 Rubber Boot - $22 Extra jets (162.5 & 167) - $10 Air Filter - $20(amazon) Mikuni Choke Cable - $30 Viper Racing Air Filter Adapter - $20 ~$520 right now. Put it all together yesterday and the engine starts and idles great. I think the 165 is a little fat for my motor (only gutted stocker). Going to try the 160 and see how she does. Just wanted to give some other people a heads up on where to get a good deal on the mikuni. |
| Author: | brickgw [ Tue Apr 14, 2015 7:34 am ] |
| Post subject: | Re: DIY Mikuni kit |
Kudos to you for the heads up. That's not chump change your saving there either. |
| Author: | cb5331 [ Tue Apr 14, 2015 8:22 am ] |
Na uh, you can't put together a carb kit for less than $500.... |
| Author: | North LA Hunter [ Tue Apr 14, 2015 8:37 am ] |
| Author: | CLICKSTER [ Tue Apr 14, 2015 9:17 am ] |
I've done it three times. |
| Author: | steinb3rg [ Tue Apr 14, 2015 9:34 am ] |
And it really didn't take much looking around either. |
| Author: | Nate [ Tue Apr 14, 2015 9:41 am ] |
Good info may have to try this |
| Author: | jerimiahw [ Tue Apr 14, 2015 9:49 am ] |
You forgot the choke |
And there are a few places that have carbs for 250 and less |
| Author: | jerimiahw [ Tue Apr 14, 2015 9:52 am ] |
At 288 plus 23 for needle and 20 for choke you are at 331 $ and the boat dr will sell it to you ready to go for 350 and usually has them at my door the next day |
| Author: | jerimiahw [ Tue Apr 14, 2015 9:54 am ] |
If you look a little harder you can find them at 250 I just often have people who want there boats right now and boat dr usually has the parts in stock |
| Author: | kirk [ Tue Apr 14, 2015 10:05 am ] |
| Author: | CypressCritter [ Tue Apr 14, 2015 11:12 am ] |
Sometimes the convenience of a kit is worth it! I just did a Big Block (CDI Marine) Stage 1 Black Death Performance System on my GTR35. I have remote side console and the only thing that wasn't direct fit was throttle cable but with a Dremel tool and a little careful trimming on cable end and drilling one hole, adjusting cable travel on console throttle assembly it works great! |
| Author: | JD145 [ Tue Apr 14, 2015 11:23 am ] |
| Author: | steinb3rg [ Tue Apr 14, 2015 11:55 am ] |
| Author: | brickgw [ Tue Apr 14, 2015 12:14 pm ] |
| Author: | banded-mallard [ Tue Apr 14, 2015 1:40 pm ] |
Im sure glad that people are finally starting to shop around. I did this exact thing about 3-1/2 years ago and the people on here though I was satan for even mentioning it. Fuck, convenience? Just because they threw in some nuts and bolts made it another $300 - $400 dollars. I said it then and I'll say it now, there screwing and preying on the stupid. With just a small amount of shopping around, you can save big time money. Not $20-$50, I mean $100's. |
| Author: | brickgw [ Tue Apr 14, 2015 2:24 pm ] |
What did you PD guys use to connect the throttle cable to the arm that comes off the back of the tiller? |
| Author: | cb5331 [ Tue Apr 14, 2015 2:31 pm ] |
I used a badass little adapter made by the one and only Bayouboy. |
| Author: | Puddler45 [ Tue Apr 14, 2015 2:47 pm ] |
Im doing the same for my 23 TM 32 - 32mm flat slide $130 but a round slide which is in BPS Kit i can be had for $100 from amazon if you wanted to save a little more $ black death intake, bps throttle lever and throttle cable $180 shipped K&N filter RC-2880 $40 from amazon Rubber flange adapter $20 from amazon So $370 aint bad at all considering i have a better carb and the upgraded throttle lever the only reason I spent $40 in the filter is to hopefully use my stock gutted exhaust. Still save almost $400 as well and could be done for under $300 if you wanted. |
| Author: | banded-mallard [ Tue Apr 14, 2015 3:39 pm ] |
[quote="brickgw"]What did you PD guys use to connect the throttle cable to the arm that comes off the back of the tiller?[/quote Several things to do. You can get a barrel or you can make one using an allen head bolt. Drill a hole through it and run wire with a crimp. I used 2 crimps for just in case. 3 years later, no problems. |
| Author: | cb5331 [ Tue Apr 14, 2015 4:12 pm ] |
Blasphemy, I tell ya! |
| Author: | banded-mallard [ Tue Apr 14, 2015 4:52 pm ] |
| Author: | jerimiahw [ Tue Apr 14, 2015 6:11 pm ] |
| Author: | brickgw [ Tue Apr 14, 2015 7:49 pm ] |
| Author: | North LA Hunter [ Tue Apr 14, 2015 8:07 pm ] |
| Author: | brickgw [ Tue Apr 14, 2015 8:12 pm ] |
| Author: | cb5331 [ Tue Apr 14, 2015 8:15 pm ] |
No, I'm talking about the throttle cable adapter. |
| Author: | cb5331 [ Tue Apr 14, 2015 8:19 pm ] |
Not a very good pic. Engine in ona stand and tiller is hangin on zipties, lol, but thats it |
| Author: | fishnmoney [ Tue Apr 14, 2015 8:27 pm ] |
| Author: | brickgw [ Tue Apr 14, 2015 8:28 pm ] |
| Author: | brycecheramie [ Tue Apr 14, 2015 8:30 pm ] |
| Author: | cb5331 [ Tue Apr 14, 2015 8:39 pm ] |
Damn, tapatalk doesn't tell you there was another post before yours. |
| Author: | Puddler45 [ Tue Apr 14, 2015 10:42 pm ] |
Pretty slick looking fab work! |
| Author: | CLICKSTER [ Wed Apr 15, 2015 6:40 am ] |
i found my 42hsr carb used on ebay in great condition. i didnt serch 42hsr i serched harley carb. i only payed 175 for my last one. |
| Author: | jerimiahw [ Wed Apr 15, 2015 8:40 am ] |
image.jpg |
| Author: | OwenDickeson [ Wed Apr 15, 2015 8:51 am ] |
Easy way to rig up CC throttle. |
| Author: | brickgw [ Wed Apr 15, 2015 9:01 am ] |
| Author: | cb5331 [ Wed Apr 15, 2015 9:15 am ] |
| Author: | cb5331 [ Wed Apr 15, 2015 9:16 am ] |
And it only took a year to get it. |
| Page 1 of 2 | All times are UTC - 6 hours |
