JD2859
Joined: Sun Apr 14, 2013 10:51 am Posts: 14 Location: la crosse, WI
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Engine running lean
Ok guys I recently put the single carb kit on my 35 vanguard also has marsh mellow exhuast with no baffles I took it out the other day put couple hrs on it ran fine no problems but when I checked the plugs one cylinder was running pretty lean and the other was perfect kinda confused on y it would do this Any ideas?
_________________ LVL3 GTR
Sat Apr 11, 2015 5:52 pm |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
brickgw
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: Engine running lean
Maybe an intake leak near the lean cylinder?
Sat Apr 11, 2015 7:34 pm |
JD2859
Gonna take the carb off and look over every thing tomorrow but any more ideas would be helpful
Sat Apr 11, 2015 8:11 pm |
Will C
Definately check the intake gasket like he said, also check your valve adjustments and it would be nice to do a leakdown test to see if that intake valve is leaking. Assuming all that suff is good then you jet the carb to be a happy medium between the two cylinders. Your stock carb has two different main jet sizes. Briggs knows that the two cylinders dont breathe equally. If all you have is an exhaust then the stock mikuni jet is usally enough but you might have to jet it up a bit.
Sun Apr 12, 2015 10:11 pm |
Jduck031
I know my stock carb is no comparison to what you have, but i was running lean, checked valves and 1 side was tighter than a bass fiddle... And i only had 7hrs on it
Sun Apr 12, 2015 10:22 pm |
Will C
Cool, hope it fixed it
Sun Apr 12, 2015 10:24 pm |
JD2859
Messed with the carb and intake no diffrence checkin valves tomorrow hopfully I find the problem
Mon Apr 13, 2015 9:39 am |
JD2859
Had to loosen up the valves help plug color a little bit but still not where they should be I'm pretty sure no back pressure is causing this but am I able to jump up to a 167.5 with out getting cylinder wash?
Tue Jun 23, 2015 8:15 am |
OwenDickeson
Show us a pic of your "lean" plug.
Tue Jun 23, 2015 8:23 am |
Will
All stock other than the carb and exhaust? I bet you have a Cheshire cat hiding in there.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Tue Jun 23, 2015 8:54 am |
