It is currently Wed Dec 17, 2025 5:13 am
[ 7 posts ] |
Gator Tail Hydraulic Steering Issue
birdseye06
Joined: Tue Apr 10, 2012 8:44 pm Posts: 15 Location: Panhandle Florida
I'm having an issue with my hydraulic steering for the second time. The hydraulic ram pushes through a SS tube below he motor to swing it left and right. After a few bumps of submerged (and not submerged) logs, and the motor slams down on the tube, eventually crimping it causing difficult steering. The first time it happened, GT replaced the tube for free, this time it's $120. They're aware of this issue, seen it before and didn't offer any ideas for a solution (other than replace in-kind). This time when it happened, it reduced my right steering to maybe 50% in that direction so I could see how this could possibly leave you stranded.
Has anyone else with console steering run into this issue? Any ideas for a work around?
_________________ 2012 Gator Tail 1860 CC with GTR 35 Stage 1
| Sun Aug 16, 2015 6:41 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
 Re: Gator Tail Hydraulic Steering Issue
Put a seastar hydro steering front mount and get that POS side mount off there! Put mine on and the only problem was I didn't tighten a fitting. No issues since then!!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Mon Aug 24, 2015 10:56 pm |
birdseye06
thanks for the suggestion, I have been looking in that direction. Were you able to use the existing steering wheel/hoses or did you have to replace everything?
| Tue Aug 25, 2015 6:51 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
I run Seastar hydraulic system. Worked good on my last one and got the same thing for the one I'm building now.
Sent from my beeper
| Tue Aug 25, 2015 7:52 pm |
Team Schmo
Joined: Sun Sep 08, 2013 8:05 pm Posts: 814 Location: Montana
_________________ You can't fix stupid
| Tue Aug 25, 2015 8:19 pm |
Over the LINE
Joined: Mon Jan 19, 2009 5:22 am Posts: 535 Location: New Orleans
Took my side mount off because with the unequal turns it was really hard to run straight across an open bay in the dark. Have had the center sea star for a few years now, really like it
_________________ 17' CAT 5 with 37 GTR
| Wed Aug 26, 2015 6:47 am |
SpecialK
I have never had hydraulic steering on a mud motor. But, from years pf experience in setting up outboards, I can tell you there is no comparison between a side mount push pull style cylinder and a centered push push cylinder. The push pull will always take more effort and wheel travel to pull. They also tend to produce more "feedback" through the steerig wheel.
Seastar is the way to go and can be easily adapted to anything...
| Wed Aug 26, 2015 8:35 am |
[ 7 posts ] |
