It is currently Tue Dec 23, 2025 6:08 pm
Reply to topic  [ 10 posts ]
 Mikuni carb
Post Mikuni carb
I have a mikuni carb on my gatortail with a Mac exhaust it runs fine and idles great but when it gets In a bind and trying to put it on the trailer it just bogs down and won't move any ideas on what to do? Thanks
Sat Aug 29, 2015 8:10 am
Post Re: Mikuni carb
Might need to adjust AF screw or the jets may need tweaking. Try adjusting the AF screw one turn either direction and see if it gets better or worse.
Sat Aug 29, 2015 9:16 am
A mikuni on stock heads is alot of carb, expecially if valves are leaking. Maybe motor is bogging from too big carb for the setup.
Sat Aug 29, 2015 10:57 am
When this happens do you have fuel coming out your overflow line? What size jets are you running?
Sat Aug 29, 2015 11:05 am
It's all stock and I haven't checked the overflow line when it happens
Sat Aug 29, 2015 11:32 am
How many hours on motor?
Sat Aug 29, 2015 11:38 am
136 hours
Sat Aug 29, 2015 2:00 pm
As the others said, check for flooding and check valve lash, air filter , fuel filter etc.If motor runs fine other then when in a bind i bet the valves are not sealing well due to the heads now being seasoned. Best to do leakdown test to verify. Might be time to get heads done. Or maybe its something else real easy to fix that im not thinkin of.
Sat Aug 29, 2015 2:17 pm
Sat Aug 29, 2015 2:45 pm
Thanks I'll look for that next time I run it
Sat Aug 29, 2015 3:45 pm
