brewdogyo
 Help.. Dixie 35HP problems!!
So recently when running my rig, when idling it just makes the most god awful screeching sound. It will last for a few seconds then go away and return again. So on and so on. Checked fluids and grease and everything seemed fine. Thinking maybe clutch? How do I know for sure? Thanks in advance
Sent from my SAMSUNG-SM-G890A using Tapatalk
Mon Oct 12, 2015 1:52 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
 Re: Help.. Dixie 35HP problems!!
Most likley the clutch or one of the bearings going bad. Crank ot up out of water and engage clutch, listen for where the sound is coming from and you will know
Mon Oct 12, 2015 2:54 pm |
ajthomas320
Joined: Fri Aug 28, 2015 7:30 pm Posts: 6 Location: Daphne, AL
I agree. If you're sure everything is greased properly. I've never taken apart a Dixie but I would hope they used sealed bearings. So there's no easy way to grease them. You could have had some mud or water blow past the seals.
Mon Oct 12, 2015 9:06 pm |
BERNIE255
The bearing towards the prop is sealed and the one near the housing is not, depending on how old it is. Regardless the bearings used are shit
Mon Oct 12, 2015 9:34 pm |
mudxxed
Joined: Thu Sep 05, 2013 4:46 pm Posts: 1398 Location: SE Bama
Bernie hit the nail on the head. Either your clutch or lower unit bearings. Just by listening you should be able to determine where the screech is coming from. Let us know what it is actually and I can help you if you have questions on how to replace.
_________________ 1651 Excel/ 35 MB HD: little of dis, little of dat
Tue Oct 13, 2015 11:32 am |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
_________________ 1754 prodigy- stage 2 GTR
Tue Oct 13, 2015 11:36 am |
mudxxed
Tue Oct 13, 2015 12:08 pm |
brewdogyo
Sorry for the late reply yall, I'll take a look at it Sunday and post it up. Thanks again for the info
Fri Oct 16, 2015 9:25 pm |
