| advice on successful 25 hp kohler mods? first timer needing http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=64368 |
| Author: | galeforce2015 [ Sat Oct 31, 2015 4:40 pm ] |
| Post subject: | advice on successful 25 hp kohler mods? first timer needing |
I have a 25hp gdlt I'm not happt with the performance of, cam anyone help out with advice for getting more out of it |
| Author: | Will C [ Mon Nov 02, 2015 9:24 am ] |
| Post subject: | Re: advice on successful 25 hp kohler mods? first timer need |
A good valve job with port cleanup, usally cleans up an old one. Common is a timing bump. Options are deck heads and shim rockers to set lash. For cam / carb upgades try lakota racing. Have you adjusted your gov up yet? You prob need a leakdown test done and a cam check. |
| Author: | 50fps [ Mon Nov 02, 2015 10:14 am ] |
Midwest super cub. 30 carb and intake kit. |
| Author: | galeforce2015 [ Mon Nov 02, 2015 12:24 pm ] |
Where should I have my governor set at? And for an intake for a bigger carb do I need the 2 barrel intake? Does an exhaust or velocity stack with a k&n help? |
