It is currently Wed Mar 18, 2026 6:15 am
[ 4 posts ] |
advice on successful 25 hp kohler mods? first timer needing
galeforce2015
I have a 25hp gdlt I'm not happt with the performance of, cam anyone help out with advice for getting more out of it
| Sat Oct 31, 2015 4:40 pm |
Will C
 Re: advice on successful 25 hp kohler mods? first timer need
A good valve job with port cleanup, usally cleans up an old one. Common is a timing bump. Options are deck heads and shim rockers to set lash. For cam / carb upgades try lakota racing. Have you adjusted your gov up yet? You prob need a leakdown test done and a cam check.
| Mon Nov 02, 2015 9:24 am |
50fps
Midwest super cub. 30 carb and intake kit.
| Mon Nov 02, 2015 10:14 am |
galeforce2015
Where should I have my governor set at? And for an intake for a bigger carb do I need the 2 barrel intake? Does an exhaust or velocity stack with a k&n help?
| Mon Nov 02, 2015 12:24 pm |
[ 4 posts ] |
