It is currently Wed Sep 02, 2026 9:08 am
Reply to topic  [ 5 posts ]
 No power in water 35 hp vanguard
Post No power in water 35 hp vanguard
My buddy's 35 hp gatortail runs fine out of the water but when you put it in the water it won't get on the wave, it bogs down.It recently started doing this after we took the back off and changed the crankcase gasket. We changed the spark plugs, cleaned the carb, cleaned values and checked them, and checked the timing. Maybe the coils ? But I don't see how they would have went bad by just taking the crankcase off. Please help
Delta lvl 3 GTR with MAC
16x54 Gator hull
Wed Jan 06, 2016 3:54 pm
Post Re: No power in water 35 hp vanguard
Pull the valve covers and make sure you're getting full travel in the valves.
Wed Jan 06, 2016 5:11 pm
Had a Longtail that did this because air was getting into the fuel line at a loose clamp on a filter. Start with the easy stuff. Valve travel like Craig said, fuel delivery buttoned up tight, etc.
Wed Jan 06, 2016 5:13 pm
Might be coils...
Sent from my SGH-I317M using Tapatalk
B. MacDonald
Wed Jan 06, 2016 6:20 pm
Check cam lift as said above also ive seen the timing gears get out of time as the cover comes off. Did u double check the timing marks before puting cover back on?
Wed Jan 06, 2016 9:00 pm
