It is currently Fri Sep 04, 2026 6:41 pm
[ 17 posts ] |
New to Mud Motors and the Forum
BlakeP
New guy here.
I have been seeing an increasing number of mud motors where I hunt in AR. They seem awesome, but I have many questions.
After reading for a while on here, it seems like the capabilities of a mud motor, which are awesome, are often negated by reliability issues. Is this accurate? If so, what are the most common issues, and why are issues with mud motors seemingly so much more prevalent than with outboards?
Also, it seems like many (most) people with mud motors are constantly having to tinker with them to get them right...i.e., adding parts, changing things, etc... Is this accurate? If so, why? And are there setups that perform properly right from the factory?
Many more questions to come regarding boats and motors, but I thought I'd start here.
| Tue Jan 05, 2016 8:39 pm |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
 Re: New to Mud Motors and the Forum
| Wed Jan 06, 2016 12:12 pm |
cb5331
They're junk. Stick with the outboard.
| Wed Jan 06, 2016 1:03 pm |
debo
Joined: Sun Jan 05, 2014 7:05 pm Posts: 143 Location: Southeast, LA
| Wed Jan 06, 2016 1:20 pm |
WestEndAngler
MMT Moderator
Welcome!
| Wed Jan 06, 2016 1:25 pm |
cheniermudder
Joined: Mon Apr 06, 2015 8:30 am Posts: 434 Location: SW Louisiana - Sabine River
As with most things in life, you typically only hear about the bad stuff. This site is no different, in that most are posting here to find help on a problem they're experiencing, so it appears that there are a lot of issues wth mud motors. As a percentage, the number of units in the field with no issues is (IMO) much greater than those that have problems. You will probably never read a post from someone proclaiming their unit just hit 500 hours without a single problem (just a euphemism terds).
Being an avid bass tournament participant and a regional manager for a major tournament trail in a previous life, I can assure you, outboards have their issues too. I've seen many pop a cork with very few hours on them.
If you decide to go mud just remember.....treat it right, and it'll treat you right.
_________________ 2010 31hp GT on a 1648 Alumacraft Jon Boat
| Wed Jan 06, 2016 7:15 pm |
duck_watcher12
Where are you hunting at in Arkansas?
| Wed Jan 06, 2016 7:21 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
_________________ 1850 & 36pd
| Wed Jan 06, 2016 8:09 pm |
deadbird8
I responded to some questions on another forum and will re-post here:
Ive just heard some bad things about these motors but it is still the motor i would like to go with.
When you read 'bad things' about a model/motor, I would look at the source of the information. You can find all sorts of negative information and horror stories about all of these motors- all models/manufacturers. They run in tough conditions- stumps, mud, laydowns, etc... not the clear water that most OB's run in.
So my question is what usually fails on them?
Common failures would be switches, ckt breakers, or trim relays (anything electrical can fail) but these are easily to troubleshoot and replace if needed. ...Common wear items are props and throttle cables.
Properly maintaining- greasing the outdrive during your annual mtc (oil change, valve lash check, greasing the frame components, check lower unit seals, muffler and case cover bolts, Checking the outdrive drain plug to ensure the lower unit seal is good and there is no water in the belt housing ...) is usually enough.
If you run sandy or sandy/silt areas you will want to keep and eye on your lower unit rear seal, sand is the devil on seals and props so do a check when you do your annual mtc (there are posts on this site that go over it in detail) to keep water out of the drive. A common new surface drive owner mistake is to trim down and grind out in sand/sandy silt- this can toast a prop in minutes wearing the cup off the end and sharpening the edges where you could skin a deer with it. Its sometimes better to walk the boat out a few yards than dig out in sand- your prop and wallet will thank you.
The Briggs big block v-twin motor has a couple of anomalies which are not specific to any brand of motor using these engines. Valve leakage and case cover gasket leakage. Valve leakage robs power and would require pulling the heads and having the valves recut/reseated- a compression test and leak down test will let you know if there is a problem. Case cover leakage is usually the result of case bolts vibrating loose. Oil seepage around the oil ports on the side near the oil filter is common, in extreme cases if running with the case bolts loose the cover can shift and crack.
These motors have a low pressure fuel pump (1-2 PSI), any air leakage in the fuel delivery system can cause problems. Common points of leakage are cheap primer bulbs, quick disconnects on the fuel tank, water separators, and loose fuel line clamps. You can read countless threads on-line about this and its not specific to any brand of motor and is usually the result of adding or changing something in the fuel delivery system.
Also any advice or things you do to make the motor last longer would be appreciated.
Regular engine mtc- change the oil and filter annually using a good high zinc oil (Boat Dr likes Amsoil 3000, diesel engine oils have higher zinc which works well for flat tappet lifters used in these motors. You can also get a zinc additive from a motor performance shop.) Change the fuel filter, clean the air filter/pre-filter, check the valve lash, lubricate the throttle cable, properly grease the outdrive, check belt tension, check the seal on the outdrive and belt housing.... A good check list of items to do before the season or putting the motor in storage for an extended period. Run good premium fuel in the motor.
In many areas you can only get ethanol blend fuel, having the motor sit up for extended periods with stale fuel sitting in the carb bowl can cause issues. Many people run Stabil or equivalent in their tanks, I personally have not had problems with this.
One thing you can do preventative for the case cover bolts when you get the motor is to remove the case bolts one at a time, clean the threads in the hole and on the bolt, reinstall with a stainless lock washer and red Loctite, torqueing it to spec (200 in lbs).
A lot of information and not meant to overwhelm you, but I tried to answer your questions as completely as possible. There are hundreds of these motors out there and most give years trouble free service if properly maintained.
| Thu Jan 07, 2016 6:43 am |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Thu Jan 07, 2016 1:15 pm |
BlakeP
Insight is much appreciated and making me feel better.
Sounds like many/most of you guys are doing your own service/maintenance, and it sounds like these motors are far easier to do this type of work on compared to an OB.
Many more questions to come.
| Fri Jan 08, 2016 7:09 pm |
Jake35gtr
Quick question to add some detail. So many post on the forum suggest performing a compression test and leak down test. What should compression be and what is tolerable on leak down?
| Sat Jan 09, 2016 8:47 pm |
cb5331
Compression should be within a couple psi on each cylinder. Uniformity is what you're looking for there. Leak down...i think briggs tolerance is something stupid like 90%  I think once it got to the 30's i'd be trying to get it fixed, personally. Less the better, but most engines seem to still run okay up into that range. The seats on a briggs are going to walk, just have to deal with it, otherwise you could be doin valve jobs at every oil change,
| Sun Jan 10, 2016 9:18 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
CB I have never heard of valve seats "walking". Please explain. We may have different terms for the same thing. Thanks stu
_________________ so many rivers, so little time
| Sun Jan 10, 2016 12:48 pm |
cb5331
Warping, shifting, not staying true..etc.
| Sun Jan 10, 2016 1:23 pm |
stualaska
OK got it. thanks.
| Sun Jan 10, 2016 2:38 pm |
cb5331
No worries. Correct if you disagree. That's just my opinion on the matter, and we all know what they say about opinions. Especially mine
| Sun Jan 10, 2016 3:06 pm |
[ 17 posts ] |
