It is currently Fri Sep 04, 2026 9:52 pm
Reply to topic  [ 16 posts ]
 Motor shut down.
Post Motor shut down.
Running wot for ten minutes. Motor dies. Try to crank. Motor turns over great does not crank. Turned just key, do not here the little whinning sound that that I usually here when the fuel pump primes. Motor is 37 efi. 40 hrs. Checked power to fuel pump with volt meter it has power. What's the deal, why would it just quit. No issues with this before.
Could it be fuel pump??
Or is it fuel pump not getting signal from motor to pump??
Sat Jan 02, 2016 4:42 pm
Post Re: Motor shut down.
The EFI has 2 fuel pumps.
Which one did you check?
Sat Jan 02, 2016 8:07 pm
Even if the fuel pump(s) have power to them doesn't mean they are working as well make sure your getting fuel from the tank first could have had a line full and then won't take suction from the tank seen many times were the fitting on the tank isn't completely pushed on or the seal fails from putting on wrong
Sat Jan 02, 2016 8:24 pm
Ok I'll take a look. What about that priming noise I hear when I turn the key to the cranking position?
Sun Jan 03, 2016 11:09 am
So for starters what exactly is the sound u hear when turning the key to the on position. Sounds like it comes from the motor?
Sun Jan 03, 2016 12:32 pm
Motor is 37 efi
Sun Jan 03, 2016 3:48 pm
So is there one in the motor? Cause that's where I hear it
Sun Jan 03, 2016 5:42 pm
Was hearing it
Sun Jan 03, 2016 5:43 pm
Yes there is one under the air filter and one mounted on side the engine.
If the pump mounted on side the engine (silver) goes out the engine will run as long as you keep pumping the bulb.
If the main pump goes out the engine will not run at all.
Sun Jan 03, 2016 7:51 pm
Ok thanks. Is the main pump something I can replace easily or do I need to take to dealer??
Sun Jan 03, 2016 8:57 pm
Sun Jan 03, 2016 10:29 pm
It is more than likely one of 2 issues. A Broken wire at the Fuel pump module or a broken ground near the relay box.
Mon Jan 04, 2016 8:58 am
Ok thanks I'll check that ou
Wed Jan 06, 2016 4:51 pm
I would bring it to your closest service center. Where are you located?
Fri Jan 08, 2016 11:12 am
I took it to the dealer in Arkansas. I will report back on the findings
Mon Jan 11, 2016 3:20 pm
