It is currently Tue Sep 08, 2026 1:56 pm
Reply to topic  [ 15 posts ]
 Decreased speed issues
Post Decreased speed issues
I have a stock 2016 MB HDR 35 on a 1751 f4. I have around 11hrs on motor been noticing speed has seemed slower. When i first got the rig i could run 28mph with 3 people and some gear. Now 2 people with dozen dakotas 2 shotguns im around 25.
Any thoughts or opinions?
Sat Jan 16, 2016 3:57 pm
Post Re: Decreased speed issues
Check for leaking valves
- Mark Twain
Sat Jan 16, 2016 4:01 pm
28 on a stock motor with 3 people?
What your prop look like.
Sat Jan 16, 2016 4:26 pm
28 mhp with a stock motor. I cant get 28 out of a modded 36 PD with 2 guys and gear in a 17/48 phowler!! Thats Awesome!!!!! Check your valves and valve lash!!
Sat Jan 16, 2016 5:30 pm
Which engine do you have?
Carb. or EFI?
Sat Jan 16, 2016 5:40 pm
I have carb motor. What do i need to do to check my valves?
Sat Jan 16, 2016 5:55 pm
I have been thinking its my prop bc i have been in some sand and logs
Sat Jan 16, 2016 5:58 pm
Sand? Measure your prop
Sat Jan 16, 2016 6:19 pm
What does it need to measure up too?
Sat Jan 16, 2016 6:23 pm
*facepalm* valve lash: search the forum, or Google it, videos on youtube.
Prop diameter: listed on the hub of your prop, since it's a big blade.
Sat Jan 16, 2016 7:17 pm
Okay thanks for yalls help
Sat Jan 16, 2016 8:03 pm
If you've been running sand it's probably a combination of valves and worn prop.
ALL of the carb'ed engines need a good valve job after you put 20-30 hrs. on the engine.
I'm not sure exactly what the MB props measure when new. IF deadbird8 doesn't chime in on this post send him a PM and he can fill you in on MB prop specs.
Sat Jan 16, 2016 8:23 pm
12.25x10pitch
Sat Jan 16, 2016 8:45 pm
I knew it, was trying to show him that the info is there if he looks for it
Sun Jan 17, 2016 1:05 am
