It is currently Tue Feb 03, 2026 8:51 pm
Reply to topic  [ 30 posts ]
 Mikuni throttle cable?
Post Mikuni throttle cable?
The directions say to trim a half inch of the black plastic off the cable by the throttle. It already has a finished metal end. Why would I need to trim off any plastic?
Sat Feb 13, 2016 6:16 pm
Post Re: Mikuni throttle cable?
Sat Feb 13, 2016 6:44 pm
1854 Prodigy DPE Level 3 HDR
Sat Feb 13, 2016 8:30 pm
Sat Feb 13, 2016 8:32 pm
Sat Feb 13, 2016 8:38 pm
Im pretty sure you cant use your factory cable with the mikuni and factory grip. Except it may work on a pro drive, been a while since I've seen a stock cable. Cant remember what the grip end looks like for sure
Sat Feb 13, 2016 8:52 pm
Sat Feb 13, 2016 9:10 pm
Id get the bps throttle grip too. If it will ffit go devil tiller handle. Thats just IMO but youd Prolly never have to worry about replacing it
Sat Feb 13, 2016 9:15 pm
Flint go ahead and get the Bps throttle and cable before you break that cheap plastic one and have to make it back by pulling the cable with pliers like I did lol
Sent from denda this
Sat Feb 13, 2016 9:21 pm
Sat Feb 13, 2016 10:14 pm
Sat Feb 13, 2016 10:20 pm
I used the stock plastic GTR throttle handle. The Mikuni kit came with a new cable. Have to use it because the stock cable won't work with it. The directions in the Mikuni kit were ok, but the changing of the fuel needle and seat as well as the trimming of the throttle cable were unnecessary.
Sat Feb 13, 2016 11:18 pm
Some of the older throttle cables would not fit down in the holder on top of the carb with the black black plastic coating on the cable so you had to trim some of the shield off to let it seat. If you cable fits all the way to the bottom of the holder trimming is not needed.
1754 prodigy- stage 2 GTR
Sat Feb 13, 2016 11:44 pm
It does not go down far enough to use the split ring. The directions did not say to replace the split ring anyway so I figured it wasn't necessary.
Sun Feb 14, 2016 6:19 am
Don't use the split ring anymore
Sun Feb 14, 2016 8:14 am
Thanks. Going to fire it up this afternoon to see if everything is installed correctly.
Sun Feb 14, 2016 1:05 pm
Sun Feb 14, 2016 7:19 pm
Runs great on the trailer. Fired right up. Spent about 2 seconds tweaking the idle. Going to put it in the water tomorrow. I am probably going to replace the throttle lever down the road. My buddy has one and it is a big improvement over the plastic one.
Sun Feb 14, 2016 8:02 pm
Sun Feb 14, 2016 8:34 pm
My hand will cramp with this new cable. There is zero slack in it so my hand is stretched out. The old cable had a ton of slack in it.
Sun Feb 14, 2016 10:14 pm
Ran the boat today.
WOW.... night and day difference. With me (180), puppy (40), full tank of gas. Boat is an 18'x60". In 3 ft of water with a slight breeze at my back I hit 30.5 on the gps. 2 ft of water into the wind 30mph at 3950rpm.
Mon Feb 15, 2016 5:04 pm
With the 3 blade GTR prop.
Mon Feb 15, 2016 5:17 pm
I had seen 27 once 3 years ago.. It was 22 with a load 25 unloaded before mods.
Mon Feb 15, 2016 6:20 pm
Mon Feb 15, 2016 6:29 pm
Not sure... whatever the carb kit came with.
Mon Feb 15, 2016 7:19 pm
Mon Feb 15, 2016 7:32 pm
Mon Feb 15, 2016 8:20 pm
I changed he needle and seat with what came in the kit. That should be good correct?
Mon Feb 15, 2016 9:02 pm
I got everything from Calen... that is who I got my GTR from 4 years ago.
Mon Feb 15, 2016 9:03 pm
