Gasket removal question
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=65656
Author:  ibfishin [ Thu Feb 04, 2016 10:28 am ]
Post subject:  Gasket removal question
What is the most efficient way to remove the factory head gasket form the block?
Author:  Russ [ Thu Feb 04, 2016 11:28 am ]
Post subject:  Re: Gasket removal question
Razor blade scraper works well
Author:  ibfishin [ Thu Feb 04, 2016 12:03 pm ]
That is what I figured. Didn't know if there was any kind of release agent on the market you guys were using in conjunction with a plastic scraper.
Author:  Russ [ Thu Feb 04, 2016 12:49 pm ]
After I scrape, I use acetone on a rag to clean any residue.
Author:  schmitt [ Thu Feb 04, 2016 1:54 pm ]
90 die grinder with 3m pad
Author:  MaXXis85 [ Thu Feb 04, 2016 2:03 pm ]
sharp razor for the thick stuff, a scotch brite pad works good for the little shit. Schmitt got it^^
Author:  Will C [ Thu Feb 04, 2016 2:16 pm ]
:lol: I like to a papertowel in the pushrod galleys to catch the small stuff. Then vacuum out after scraping. Makes for a nice cleanup. Skip on the grinder :lol:
Author:  ibfishin [ Thu Feb 04, 2016 2:26 pm ]
I put paper towels in the galleys, razor scraped, scotch brite, and acetoned.
Author:  DmaxHunter [ Thu Feb 04, 2016 4:52 pm ]
I go get the girl that works the local corner, run a lil of dat crotch rot on the case. Let it set, wipe away and your good to go. No need for tools
Author:  ibfishin [ Thu Feb 04, 2016 6:48 pm ]
That might work as well.... did not think about the blue waffle ooze.
Author:  richard nagon [ Thu Feb 04, 2016 9:57 pm ]
Permatex gasket remover. oven cleaner and a plastic scraper or a plastic credit card edge to scrape with. I have never seen a engine builder yet that used a die grinder and rollex discs. There is a ra finish that needs to be maintained on a aluminum head surface. Also disc dust can migrate in to places it shouldn't be in.
Author:  tylermk5 [ Tue Apr 26, 2016 1:01 pm ]
Loctite makes a paint striper/gasket remover it works well.
